When i turned on the pc, the mobo light and the fans turned on but the monitor didnt detect any source.  Then,  after several minutes it turned off by itself. It kept like that for several times but with shorter interval. After that several times, the pc run normally. Is it a psu problem? Or something else?
Psu: simbadda 380W
Core 2 duo e8400
Hd 5500 series
4gb ddr2
(sorry for bad english)
https://linustechtips.com/topic/844044-psu-problem/
16 minutes ago, Comic_Sans_MS said:
Something is dead. If your PSU was dead, it wouldn't make your computer do anything.
What happens when you remove the GPU and run off the integrated GPU on your motherboard?
Not necessarily true, it could have a fault and perhaps is overheating or something?
I edit my posts a lot.
https://linustechtips.com/topic/844044-psu-problem/#findComment-10531035
1 hour ago, shardoak said:
I asked if its psu problem or not, because before this problem My psu ever produce cracking sound
It's from a company I've never heard of and claims to output 380W so I'd replace it regardless of whether or not it's the solution to your problem.
https://linustechtips.com/topic/844044-psu-problem/#findComment-10531514
15 hours ago, jonnyGURU said:
Ok.  So this isn't a new build, but one that worked previously?
Could be PSU, but could be mobo, etc.
What motherboard do you have?  Does it have an on-board speaker or a post code LED?
Yes this is an old pc that work well before.  My motherboard is gigabyte ga -ep43-ud3l
https://linustechtips.com/topic/844044-psu-problem/#findComment-10534357
Here is a review of that unit. It wouldn't fill me with confidence having that inside my pc.
https://www.hardwareinsights.com/simbadda-sb-380w-power-supply-review/#First-Look
Pros
  • Good voltage regulation
Cons
  • Can’t deliver anything with the ripple in spec (−10)
  • Low quality capacitors
  • Low quality fan
  • Two-transistor 5vsb
  • Inadequate input filtering
  • Soldering could be better
  • Failed under 320W Load
  • Inefficient
  • Ugly
Final comments: This would have to be one of the worst power supplies I have ever tested. The ripple was way too high, it failed well below its rating, and the build quality is absolutely appalling. These cheap power supplies should be avoided at all costs.
Score: 0/10
Sounds like one of those gutless wonders from JG's site.
https://linustechtips.com/topic/844044-psu-problem/#findComment-10534503
Sounds like your build was smited from above, toss that mess and build a new one. The whole thing is cancer.
Intel i7-7700k @ 5.1ghz | Asus ROG Maximus Hero IX | Asus ROG Poseidon Platinum 1080ti @ 2126mhz | 64gb Trident-Z DDR4 @ 3600mhz | Samsung 960 Pro 1tb @ 3500mbps/2500mbps | Crucial 240gb SSD | Toshiba 4tb 7200rpm HDD w/ Crucial 128gb SSD cache | Corsair Hx1000i PSU | EK 360mm Coolstream XE Radiator | EK-Supremacy Evo Waterblock | EK-DDC 3.2 PWM Elite Edition Pump | EK-RES X3 150 RGB Reservoir | Primochill AdvancedLRT Clear Tubing | Primochill VUE UV Blue Coolant | Corsair 570x Crystal RGB Case | 4x 30cm CableMod UV/RGB Widebeam Hybrid Led Strip | 3x 120mm Corsair SP120 RGB Fans | 3x Noctua NF-A14 iPPC 3000rpm Fans | 3x Noctua NF-A12x15 Fan | CableMod ModFlex PSU & SATA Cables | Asus ROG Swift 27" 4k IPS w/G-Sync & LG UD68 27" 4k IPS w/Freesync |
https://linustechtips.com/topic/844044-psu-problem/#findComment-10535919
