Use proper English, I can't understand a word of this.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/844015-about-overheating/#findComment-10530701
That doesn't help if OP's first language isn't English...
https://linustechtips.com/topic/844015-about-overheating/#findComment-10530712
Overheating doesn't mean CPU is broken. It means cooler isn't capable of handling load and temps of CPU. If CPU would be legit dead, it wouldn't have effect on anything. It just wouldn't power on. Dead or dying mobo might damage RAM and CPU, but thats unlikely. Dying PSU has most chances of killing all things connected to it. They only need one power surge to die.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/844015-about-overheating/#findComment-10530731
You right. I already change my power supply and it give damaged into my motherboard and right now my graphic card. I know FX- Series right now is outdated processor. I need changed my graphic card to Msi Gtx 1050 Ti 4gb Gaming X as long Gtx 1060 3gb is bottleneck. I scared if my Processor was given damaged too.
https://linustechtips.com/topic/844015-about-overheating/#findComment-10530751
I'd be asking yourself *why* the CPU overheated? I haven't seen a case of overheating on a CPU, where thermal shutdown didn't kick in, in a very very long time.
We need more details, what happened to cause the overheating?
And CPU, GFX, and PS are all discrete elements. As DRM said, one dying is *highly* unlikely to affect the other, unless it was a power surge through a cheap Power Supply, then you have bigger issues.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/844015-about-overheating/#findComment-10530778
If you can, test every part with another system that 100% works. Its possible that its only mobo which isn't working and would cause issues on other parts.
https://linustechtips.com/topic/844015-about-overheating/#findComment-10530830
