Just now, man_named_corn said:
On my z270e board when I boot I get a message saying there is a problem with the CPU fan it says to adjust or disable the fan speed low limit
If you have an AIO pump on the unit make sure your fan curve is not too low for the pump to start some AIO's depending on the unit you have require full 12V.
https://linustechtips.com/topic/843925-aio-pump/#findComment-10529987
I've had this setup running for a couple of weeks I clicked resort to default settings on my mobo and now this is coming up I don't remember what I did the first time
https://linustechtips.com/topic/843925-aio-pump/#findComment-10529992
Go into the BIOS and check the fan curve you have setup for the pump.
https://linustechtips.com/topic/843925-aio-pump/#findComment-10529998
7 minutes ago, W-L said:
That looks to be on the AIO pump header right now, do you have the pump cable connected to the CPU header?
Should it really matter if I had it working before?
And I honestly don't know/cant tell this my first time using an aio and I don't remember how I did it
https://linustechtips.com/topic/843925-aio-pump/#findComment-10530023
By defaulting it could have changed all the settings so you will need to go back and reconfigure them for your setup.
https://linustechtips.com/topic/843925-aio-pump/#findComment-10530036
But I don't know what settings I had for the fan on the CPU to get that message to go away and allow for boot
As suggested check your AIo's pump connection first, if it's connected to the CPU header make sure it's setup so that the fan curve is high enough or to just full 12V to ensure it starts.
https://linustechtips.com/topic/843925-aio-pump/#findComment-10530051
If you don't have a header connected to the CPU_FAN header, you need to set "ignore" under the monitoring header for CPU fan speed. Asus boards will not boot until there is something spinning on the CPU_FAN header, unless if you you explicitly tell it to ignore it.
https://linustechtips.com/topic/843925-aio-pump/#findComment-10530424
