No, it's not compatible.
You've got a socket 1150 motherboard and a socket 1155 CPU
Edit: Also, the motherboard comes with a NIC, you don't need a separate one.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/843815-is-my-build-compatible/#findComment-10528692
