what is better ?? {PLS HELP|
Brine_gr
Hi guys i want to buy pc monitor from lg with 1 ms 75 hz and freesync 1080p
its better to buy 1060 6gb or rx 560 ? and why
I know gtx 1060 its better than 560 ....but .rx560 with freesync is better ??
thank you for your time
Freesync imo is pointless unless you plan to get less than the refresh rate, which in this case is 75hz which is easy to hit in most games at high at 1080p, even if its an ultrawide. The 1060 6gb would be the better option.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
