I tried changing my dell N5010 CPU (Pentium P6000) with a I5-3320M to see if they were compatible as I found mixed answers on the internet. The pentium CPU uses the PGA988 socket while the I5-3320M uses FCPGA988, hence my question. Anyway when I turned it on I got 3 short beeps with a black screen, according to my research that means "Failure in first 64k". I swaped it back to the P6000 and it booted as expected.
This only brought more questions, what are the differences between those sockets? is there a way to fix this issue? will it eventualy work?
https://linustechtips.com/topic/843262-changed-notebook-cpu-got-memory-problem/
There is no actual difference both are flip chip land grid arrays (fclga) it could be not supported on your motherboards bios.
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
It's not supported. P6000 was Arrandale, which is gen 1 of the Core i architecture. Meaning that Ivy Bridge i5 you bought won't work at all since the motherboard won't recognize it. Ever.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
