Specs?
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/843251-my-first-ever-pc-build/#findComment-10523373
Well, mistakes...
First, you could have got the new 8700k, next a h100i is not needed, heck a 212evo would do good if you don't overclock. If you want to overclock I guess the masterliquid series or h80i would be good enough or for air the noctua nhd15 or be quiet dark rock pro 3. You wasted your money on that dominator, a tridentz rgb would have costed less and looked a billion times better. Again, that firecuda was not necessary, you could have just used an optane with a 2tb barracuda, which would have been much faster than the firecuda. Really, you spent so much on useless things, but didn't get a GTX 1080 ti but got a GTX 1080? GOD! Phanteks is well, based on preferences, but you didn't have to spend so much on a case, mastercase pro 5 would have done well or the awesome h500p case that is going to release on october 10 for $150 which is really way better than your phanteks case. You could have just bought a 650w psu. An rgb hub, ok. Wow, I don't know what to say, a tn 1080p for that price? check out the samsung chg70 1440p 144hz VA 1ms panel which would have been my choice. A g402 is much much better than razer mamba. A lot of mistakes but good i guess, it's all about your preferences. the 1080 though, a 1080ti would be much better......
https://linustechtips.com/topic/843251-my-first-ever-pc-build/#findComment-10523447
27 minutes ago, Chaos Gamer said:
Well, mistakes...
First, you could have got the new 8700k, next a h100i is not needed, heck a 212evo would do good if you don't overclock. If you want to overclock I gues the masterliquid series or h80i would be good enough or for air the noctua nhd15 or be quiet dark rock pro 3. You wasted your money on that dominator, a tridentz rgb would have costed less and looked a billion times better. Again, that firecuda was not necessary, you could have just used an optane with a 2tb barracuda, which would have been much faster than the firecuda. Really, you spent so much on useless things, but didn't get a GTX 1080 ti but got a GTX 1080? GOD! Phanteks is well, based on preferences, but you didn't have to spend so much on a case, mastercase pro 5 would have done well or the awesome h500p case that is going to release on october 10 for $150 which is really way better than your phanteks case. You could have just bought a 650w psu. An rgb hub, ok. Wow, I don't know what to say, a tn 1080p for that price? check out the samsung chg70 1440p 144hz VA 1ms panel which would have been my choice. A g402 is much much better than razer mamba. A lot of mistakes but good i guess, it's all about your preferences. the 1080 though, a 1080ti would be much better......
that is a lot of mistakes. xD
https://linustechtips.com/topic/843251-my-first-ever-pc-build/#findComment-10523544
1 hour ago, Kasin said:
im not from the us so the price is a little off
Neither am I and I know what it feels like, but you could have made a better build than what you have now with the changes I mentioned, especially the GPU.
i will be getting a new monitor soon 1440p or 4k, any suggestions?
I did already-
I think this is the best for the price, for a few reasons. Starting with the response time, I guess you know what that means right? 1440p VA monitors like acer predator or asus rog are great but they have response time of 4ms, but the aforementioned samsung monitor has only 1ms, which is great for gaming, and it has 144hz, believe me 240hz and 144hz don't have a huge difference. It is curved and 32", not ultrawide. VA so colors look awesome, especially with that quantum dot, so colors are accurate, and this helped me a lot in games like bf4, where I would see camping enemies in dark areas first. Looks great too. But it doesn't have G-sync, so there are other monitors too, like the to be released acer predator x35 or ROG Swift PG27UQ or ROG Swift PG35VQ. These are just a few awesome monitors, just search for the monitors within your budget.
https://linustechtips.com/topic/843251-my-first-ever-pc-build/#findComment-10523933
