Which cable do i need
Solved by G27Racer_188,
42 minutes ago, Slimeey said:So i recently got a 1050ti and have 2 montiors one is hdmi and the other is vga.The 1050ti only has a hdmi dl dvi and a dp 1.4 Which cable adapter should i get if i wanna change dl dvi to vga?Can u drop me some links thanks
You are going to need an active adapter (since you need to convert from digital to analog) either
displayport to vga active adapter
or
The direct DVI to VGA adapters like @GER_T4IGA suggested won't work since DVI port on 1050Ti is only for digital DVI (DVI - D) and does not have four additional holes for four pins around the flat connector for analog signals (DVI - I), so it is physically impossible to plug it in.
