RAM Upgrade Problem
Go to solution Solved by sohayel_nafi,
all right guys i got it, i was the bios, but thnx for your help
does the new ram show up in the bios?
Personal Build Project "Rained-On"
helped building up the CPU Overclocking Database and GPU Overclocking Database, check them out ;)
#KilledMyWife #MakeBombs #LinusIsNotFunny || Please, dont use non-default grey font colors. Think about the night-theme users! ;)
https://linustechtips.com/topic/84239-ram-upgrade-problem/#findComment-1146850
Omg Vuse srsly? lol jk .. err you might have already reached the max ram supported for your motherboard
could you dump your specs?
------------------------------------------------------I HAZ SHINY----------------------------------------------------------
https://linustechtips.com/topic/84239-ram-upgrade-problem/#findComment-1146880
Hey,
So I had 16GB installed on my pc and i bought another pair of 16GB but my pc is showing me only 16GB, using OS Windows 8.1, Need help
Going to need some more info here.
Motherboard make and model
Ram make and models
also have a look in the bias and make sure each chip has registered with it.
Updating you bios may also add support for newer ram chips as well.
https://linustechtips.com/topic/84239-ram-upgrade-problem/#findComment-1146971
