that's weird... are you using the drivers from Windows update or from amd's website itself?
She/Her
Phone: OnePlus Nord CE 5G | 128GB | 8GB Ram
Main Desktop: Ryzen 5 3600 | GTX 1060 6GB | 32GB Ram
Main Laptop: Acer Aspire V3-771G | Core i7 3612QM | 16GB
https://linustechtips.com/topic/842103-i-need-help/#findComment-10510514
1 minute ago, Syn Messer said:
Full specs?
Otherwise just looks like your unable to overclock. It is still showing what looks like your GPU at the bottom like it should.
Also, I don't recommend posting something twice, even if you do change the title.
in game it writes gpu usage is 0% few later 100% than 0% ... 100% and atc
https://linustechtips.com/topic/842103-i-need-help/#findComment-10510521
- Threads Merged -
No need to post the same thing twice.
Give the forum time to respond to your issue.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/842103-i-need-help/#findComment-10510542
