I believe the components are too small for anything.
All i I can reasonably recommend is the camera, speaker, microphone, and screen can maybe be repurposed.
Otherwise it may be a smartphone that you can write apps for if not the above recommendations.
even reusing the screen will not work unless he manages to get some kind of interface board that can "talk" to it.
i agree that phones are not really a good base for a project, everything is to tighly integrated to be reused for something else.
