this is the new rig i am going to start building.
but i am stuck on a few things:
  • i don't if i should air cool the CPU or to water cool it with the cooler in the list.
  • i can't make my mind up, should i use 16gb or 8gb of RAM
other than them decisions id really like a general feedback as well, thanks!
Component   Selection Base Promo Shipping Tax Price Where
CPU 590d9c982550da4f2f69490c5f9c0902.256p.jpg £285.54       £285.54 Aria PC   Buy
CPU Cooler 41teX5r0nNL.jpg £44.99   FREE   £44.99 Scan.co.uk   Buy
Motherboard 61dWxjTPSJL.jpg £190.93   £8.20   £199.13 Alza   Buy
Memory 144d7a9578a5d60ffc3e91de70de59ce.256p.jpg £121.98       £121.98 Ebuyer   Buy
  Add Additional Memory
Storage 41EPwbR-HfL.jpg £74.52   £0.98   £75.50 BT Shop   Buy
  Add Additional Storage
Video Card 111c7f04e16987dc923e1d19597af786.256p.jpg £217.41       £217.41 Amazon UK   Buy
Case 96e46cd7abdf88e5fd2d5ac8aa0fff36.256p.jpg £84.37   FREE   £84.37 Box Limited   Buy
Power Supply 51cpdkwnz-L.jpg £84.93       £84.93 Ebuyer   Buy
Optical Drive   Choose An Optical Drive
Operating System c9b365727400c92a7ffcb533826dd224.256p.jpg £82.74       £82.74 Aria PC   Buy
Base Total: £1187.41
Shipping: £9.18
Total: £1196.59
https://linustechtips.com/topic/840962-need-help-with-new-rig/
If you want silence and better overclocks, water cool it.
16Gb memory is the sweet spot for pretty much everything.
Also that's probably the best looking AM4 motherboard I've seen.
Good luck!
https://linustechtips.com/topic/840962-need-help-with-new-rig/#findComment-10497476
Good luck!
thanks very much, ill go with this build then thanks again.
https://linustechtips.com/topic/840962-need-help-with-new-rig/#findComment-10497485
Get a cheaper motherboard and an R7 1700. Get 16GB of faster RAM. Don't spend that much for your OS. Get a better SSD(MX300 or 850 EVO). You don't need an AIO for Ryzen, it's pretty efficient. A nice air cooler will be quieter and cool Ryzen 7 perfectly adequately.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/840962-need-help-with-new-rig/#findComment-10497508
CPU: AMD - Ryzen 7 1700 3.0GHz 8-Core Processor  (£251.94 @ Aria PC)
CPU Cooler: be quiet! - Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  (£50.38 @ Amazon UK)
Motherboard: Asus - STRIX X370-F GAMING ATX AM4 Motherboard  (£171.14 @ Alza)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3200 Memory  (£119.65 @ Amazon UK)
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive  (£131.94 @ Aria PC)
Video Card: Palit - GeForce GTX 1070 8GB Dual Video Card  (£365.94 @ Aria PC)
Case: Fractal Design - Meshify C ATX Mid Tower Case  (£79.99 @ Amazon UK)
Power Supply: EVGA - SuperNOVA G3 (EU) 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (£76.77 @ CCL Computers)
Total: £1247.75
A bit more expensive but GTX 1070 instead of 1060. You can drop the Dark Rock Pro 3 for now and just run stock cooler, or drop the 1070 to a 6GB 1060 to get the system under £1200
https://linustechtips.com/topic/840962-need-help-with-new-rig/#findComment-10497517
got any recommendations for an air cooler?
https://linustechtips.com/topic/840962-need-help-with-new-rig/#findComment-10497520
Total: £1247.75
very good forgot the r7 1700 comes with a cooler
https://linustechtips.com/topic/840962-need-help-with-new-rig/#findComment-10497523
Yeah, stock cooler is pretty decent too. The DRP3 will perform significantly better but you can run stock cooler for now and upgrade to something better, like the DRP3 later when you have some more money. Worth it to get the GTX 1070 in the £1200 budget IMO.
If you're just gaming with the system, you might even want to wait a week for an i5-8600k
https://linustechtips.com/topic/840962-need-help-with-new-rig/#findComment-10497539
seems likely just checked intels website. the reason i went for AMD in the first place was because intel only offered quad core. nut the new i5 has 6 cores now.
https://linustechtips.com/topic/840962-need-help-with-new-rig/#findComment-10497564
@Scubabyron23
Post the uk.pcpartpicker.com permalink. Better yet, click [bb], then copy & paste the result in your post.
How is the system to be used?
Did you consider waiting a week or two to see if Coffee Lake cpu offer better price/performance?
Typically Ryzen cpu do better with higher speed memory.
Windows 10 OEM license does not permit use in DIY builds. Windows 10 Home (32/64 bit) or (64 bit) on USB or download are for DIY builds.
The WD Green M.2 drive is SATA III, not NVMe.
https://linustechtips.com/topic/840962-need-help-with-new-rig/#findComment-10497577
October 5th for release of 8600k and 8700k, along with Z370 motherboards so I'd suggest doing this;
CPU: Intel - Core i5-7600K 3.8GHz Quad-Core OEM/Tray Processor  (£218.99 @ Overclockers.co.uk)
Motherboard: Asus - STRIX Z270F ATX LGA1151 Motherboard  (£151.80 @ Aria PC)
Total: £1195.46
but with an 8600k and Z370 motherboard obviously. Grab an Asus Strix or similar motherboard for £150-160. 8600k will out-perform Ryzen in games, and handle multicore stuff pretty well, but Ryzen 7, or even Ryzen 5 will be better than 8600k for streaming, content creation, and other multicore tasks. With the 8600k, you get GTX 1070 and DRP3 within £1200.
https://uk.pcpartpicker.com/product/9TsKHx/antec-power-supply-tp750c
Alternative PSU you could get. The 750W PSU will give you SLI support so you can easily add a 2nd GTX 1070 at any point if you want, but it's non modular.
https://linustechtips.com/topic/840962-need-help-with-new-rig/#findComment-10497751
