Hopefully soon I am going to be able to build my and planning it has been pretty easy except for one part: RGB.
Im building a Ryzen system on a Asus ROG Strix B350-F motherboard in a Phanteks Eclipse P400 Tempered Glass Edition. The cooler I chose is the DEEPCOOL Gamer Storm Captain 240EX RGB that comes with two 120mm RGB fans. Im also planning on getting an extra Deepcool 120mm RGB fan. now the problem I am having is trying to figure out how i get all of the lights to sync up with the Asus Aura Sync with only two RGB headers on the motherboard. The header closer to the socket I am planning on using for the RGB on the pump and i plan on using the header on the bottom for everything else in the system. The P400 TGE comes with a rgb strip i plan on using and as far as i know it is the normal style of connector i have seen, but the power button and logo rgb is controlled with a rgb controller but with an adapter for each of them i can make them use the normal four pin connector. Now the thing i need help on is how the heck do i connect the three rgb fans, the led strip, power button, and logo all to one connector. Im perfectly okay with them all being the same color, i just need to know how i would be able to connect them all. Any help would be AMAZEBALLS!
https://linustechtips.com/topic/840757-need-rgb-help/
For the RGB header you can use splitters on them for multiple devices as long as you do not exceed it's max rating. The RGB fans if they have the ability to interface with Aura sync just needs to 4 pin RGB headers plugged in as for the LED strip you will need to get an adapter for it to work as Phanteks uses keyed JST connectors.
http://www.phanteks.com/PH-CB_RGB4P.html
-Moved to Modding Section-
https://linustechtips.com/topic/840757-need-rgb-help/#findComment-10495775
Would I use one like this? https://www.amazon.com/gp/product/B072K21JVF/ref=ox_sc_act_title_3?smid=AVK94F2Q2TO8D&psc=1
https://linustechtips.com/topic/840757-need-rgb-help/#findComment-10495783
Nope, it doesn't come with RGB fans.
The P400's RGB controller accepts the strip as well, so only 1 connector for everything Phanteks
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/840757-need-rgb-help/#findComment-10495811
Well this one i found comes with RGB fans. https://www.amazon.com/gp/product/B07175CYWL/ref=ox_sc_act_title_7?smid=A1TG24VCRPTZ06&psc=1
https://linustechtips.com/topic/840757-need-rgb-help/#findComment-10495814
9 minutes ago, foxtrot247 said:
That unit is a gamerstorm rebadged looking at the fan it does look like it can all use aura sync.
http://www.deepcool.com/product/dcoolingaccessory/2017-07/12_6836.shtml
https://linustechtips.com/topic/840757-need-rgb-help/#findComment-10495837
--confusion intensifies--
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/840757-need-rgb-help/#findComment-10496881
