I am helping my girlfriend build a rig octance, GPU renderer.
I already bought: https://www.asus.com/us/Motherboards/ROG-STRIX-Z270F-GAMING/overview/
I have seen many images of the motherboard supporting 2 GPUs but am wondering if it could fit another and would there be enough PCIe lanes?
The plan for the build is to get an initial 1080Ti and possibly another in the future.
Octane is able to use scale with multiple GPUs of different types, so I was going to also include a 670 that I have gathering dust.
Would this motherboard support 3 GPUs: x2 1080Ti & x1 670 or should I return the motherboard and opt for another motherboard for future-proofing in the sense I want add more GPUs?
https://linustechtips.com/topic/840669-help-with-motherboard/
The Z270 chipset itself gives you 14 PCIe lanes in conjunction with however many are on the processor you choose. As long as you're not running them in SLI it should be able to use three GPU's, as that board is only capable of two way SLI.
Main System-
Case: Lian Li PC-O11 Dynamic PCMR Limited Edition
Motherboard: Asus X570 Crosshair VIII Hero WiFi
CPU: AMD Ryzen 9 3950X
GPU: Asus GeForce RTX 2080Ti Strix OC
RAM: 4x16GB (64GB) G.Skill Trident Z Neo DDR4 @ 3600MHz/C16
Storage: 1x Samsung 970 Evo 1TB NVMe M.2 SSD (OS), 4x Samsung 860 Evo 2TB SATA SSD
PSU: EVGA Supernova G3 1000
Cooling: Custom Loop, EKWB Quantum Velocity Copper/Plexi w/ D-RGB Upgrade Kit and Black Frame, EKWB Quantum Vector Strix Nickel/Acetal D-RGB w/ EKWB Strix Backplate in Black, Watercool MO-RA3 420 LT (180-200mm Fan Mount, Classic Black Grill High Version, Wall Mounting Bracket, Heatkiller Tube Mounting Bracket, PCIe Slot Terminal Adapter), Heatkiller Tube 200 w/ EKWB D5 PWM Pump, Bitspower Fittings, 6x EKWB Vardar X3M D-RGB 120mm Fans, 4x Noctua NF-A20 Chromax 200mm Fans, EKWB ZMT Tubing, EKWB HD-PETG Tubing
ITX System-
Case: NCase M1 V6.1
Motherboard: Asus X570 ROG Crosshair VIII Impact
CPU: AMD Ryzen 9 3900X
GPU: NVIDIA GeForce RTX 2080Ti Founders Edition
RAM: 2x16GB (32GB) G.Skill Trident Z Neo @ 3600MHz/C16
Storage: 1x Samsung 970 Evo Plus 500GB NVMe m.2 SSD (OS), 1x Samsung 860 Evo 2TB m.2 SSD (Storage)
PSU: EVGA Supernova 650 GM (SFX)
Cooling: Custom Loop, Watercool Heatkiller IV Pro Black Copper (AM4), Watercool Heatkiller IV RTX 2080Ti Acetal Nickel w/ Black Backplate, 2x XSPC TX240 Radiators, Iceman Cooling Ice P5 Pump/Reservoir Combo, Bitspower Fittings, EKWB ZMT Tubing
https://linustechtips.com/topic/840669-help-with-motherboard/#findComment-10495064
Those 14 lanes provided by the chipset are still limited by x4 when communicating to the CPU. This board will probably work with 3 GPU'S (x8, x8, x4 config) check your manual to make sure.
System specs:
4790k
GTX 1050
16GB DDR3
Samsung evo SSD
a few HDD's
https://linustechtips.com/topic/840669-help-with-motherboard/#findComment-10495236
Thank you for clarifying. Left that part out.
Main System-
ITX System-
Case: NCase M1 V6.1
https://linustechtips.com/topic/840669-help-with-motherboard/#findComment-10497797
18 hours ago, SeriousTyro said:
Nevermind, I got a i7-7700k and it only has 16 PCIe lanes.
I only be able to use 2 GPUs: x8 and x8
The 7700k actually has 20 lanes  4 are dedicated to the chipset and the rest are open to expansion slots.
While you can use the chipset lanes for a GPU, these lanes also handle all the i/o as well. This GPU might be bandwidth starved compared to the others.
System specs:
4790k
GTX 1050
16GB DDR3
Samsung evo SSD
a few HDD's
https://linustechtips.com/topic/840669-help-with-motherboard/#findComment-10498115
