Need Two More Monitors
So with my current build that I just finished like 2 or 3 months ago I only have one monitor and I am using my TV as a second but soon I will be getting my new desk and buying a triple monitor mount. I am not that intrested in triple monitor gaming but more for content creation, watching youtube and maybe some other things. I am looking for them to be 27 inches 2560x1440 and prefer IPS and the monitors don't have to be from the two I have on here these are just what I found when I was first thinking of building my PC. Oh and price range is preferably less then $1,000 USD for both so $500 each.
Monitors I Am Looking At
Asus
Acer
Current Build
PCPartPicker part list: https://pcpartpicker.com/list/yB7X8K
Price breakdown by merchant: https://pcpartpicker.com/list/yB7X8K/by_merchant/
CPU: AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor  ($418.47 @ Amazon)
CPU Cooler: NZXT - Kraken X62 Rev 2 98.2 CFM Liquid CPU Cooler  ($154.79 @ SuperBiiz)
Motherboard: Gigabyte - GA-AX370-Gaming K7 ATX AM4 Motherboard  ($194.06 @ Amazon)
Memory: G.Skill - Trident Z RGB 32GB (4 x 8GB) DDR4-3200 Memory  ($393.99 @ Newegg)
Storage: Samsung - 960 EVO 1TB M.2-2280 Solid State Drive  ($443.99 @ Amazon)
Storage: Seagate - Barracuda 3TB 3.5" 7200RPM Internal Hard Drive  ($79.99 @ Amazon)
Video Card: Asus - GeForce GTX 1080 Ti 11GB STRIX GAMING Video Card  ($764.98 @ Newegg)
Case: Phanteks - Enthoo Evolv ATX Glass ATX Mid Tower Case  ($189.99 @ Amazon)
Power Supply: EVGA - SuperNOVA P2 850W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($139.99 @ Amazon)
Operating System: Microsoft - Windows 10 Pro Full 32/64-bit  ($189.00 @ B&H)
Wireless Network Adapter: Gigabyte - GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($38.89 @ OutletPC)
Case Fan: NZXT - Aer RGB140 (3-pack) 71.6 CFM  140mm Fans  ($89.99 @ SuperBiiz)
Case Accessory: NZXT - Hue+ LED Controller  ($58.90 @ OutletPC)
Monitor: Asus - PG279Q ROG Swift 27.0" 2560x1440 165Hz Monitor  ($749.00 @ Amazon)
Other: RODE PSA1 Swivel Mount Studio Microphone Boom Arm  ($99.00 @ Adorama)
Other: Focusrite Scarlett Solo (2nd Gen) USB Audio Interface with Pro Tools | First  ($99.99 @ Adorama)
Other: NZXT Internal USB Hub
Other: VideoSecu One Pair of Side Clamping Speaker Mounting Bracket with Tilt and Swivel for Large Surrounding Sound Speakers MS56B 3LH  ($21.49 @ Amazon)
Other: Kanto YU6 Powered Speakers with Bluetooth and Phono Preamp - Matte White  ($389.99 @ Amazon)
Other: Audio-Technica AT2035 Large Diaphragm Studio Condenser Microphone ($149.99)
Total: $4666.49
Generated by PCPartPicker 2017-09-29 02:17 EDT-0400
PC Build
Ryzen 1800x
Asus Strix 1080ti
G-Skill Trident z RGB 32gb 3200mhz
Gigabyte K7 motherboard
NZXT Kraken x62
EVGA Supernova P2 850w
Phanteks Enthoo Evolv ATX TG
SAMSUNG 960 EVO M.2 1tb
Seagate Barracuda 3tb
Gigabyte WiFi and Bluetooth Card
x3 NZXT Aer RGB Fans
NZXT Hue
https://linustechtips.com/topic/840439-need-two-more-monitors/
  Hide contents
Asus
Acer
Current Build
  Hide contents
Total: $4666.49
I suggest to buy the same monitor you currently have, and the leftover £250 for 60Hz IPS 1440p display for YT videos.
Unless you're not planning to buy them for gaming since you have a gaming dedicated display, then I'd recommend AOC 2x 4K displays as it gives you plenty of space when it comes to PC work and you're not resolution limited in anything really. Plus you'd pay much less than 1000 bucks.
Not located in US so this is an example: http://www.ebay.com/itm/LG-27MU58-B-Black-27-IPS-GTG-5ms-LCD-3840-x-2160-UHD-4K-FreeSync-Technology-/282670843261?hash=item41d07ec57d:g:-ToAAOSw5B1Zyw1V
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10492694
Yeah I am not planning on gaming on them, so I will look into it can you link me the AOC you were talking about?
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10492701
The link I gave you is a decent one. 27" 4K IPS display. Buy two of those and you're set!
I personally have AOC but I put LG one below. LG is a really good brand.
I don't know US sites so sorry for E-Bay link: http://www.ebay.com/itm/LG-27MU58-B-Black-27-IPS-GTG-5ms-LCD-3840-x-2160-UHD-4K-FreeSync-Technology-/282670843261?hash=item41d07ec57d:g:-ToAAOSw5B1Zyw1V
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10492706
The one I listed previously is same and is cheaper.
https://www.amazon.com/AOC-Q2775PQU-Ultra-computer-monitor/dp/B0196QNQHW/ref=sr_1_1?ie=UTF8&qid=1506667157&sr=8-1&keywords=AOC+Q2775PQU
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10492709
1 minute ago, TheNaitsyrk said:
Yeah I will probably end up getting two of the LG ones with my Newegg card cause it is cheaper on there and I can pay it off in 12 months. But I have one question how weird is it to have two different resolutions side by side?
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10492715
I have 4K and 1080P, so if I try to drag the mouse to the left right side where my 1080P is then you can't if it's lower down the monitor, since 1080P is 4x smaller than 4K. Other than that, it's not really different, things on the display are smaller due to resolution but it doesn't bother me really. I use the 1080P for movies.
Plus you can game on the 4K display too if you like quality picture. I see no issues with that. I personally prefer 4K since at 4K I won't be getting more than 60-80 frames depending on a game anyway.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10492716
Thats the only thing I am hesitant on is the scaling.
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10492726
Just bought 2 of http://www.lg.com/uk/monitors/lg-27UD68P.
Amazing compared to my old TN Monitor ofcourse.
Got them standing for now till i find a Good triple monitor mount solution, since my current one is not quite adjustable.
They will also look amazing with a Asus Monitor in the middle, which i'm planning to do once it releases.
Quote or mention me if not feel ignored
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10492758
Glad I helped!
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10493012
51 minutes ago, TheNaitsyrk said:
Glad I helped!
That wasnt me but you did help lol, but I am still looking into how big of a difference the scaling would be because I would like to be able to smoothly move things back and forth from screens.
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10493098
That will not be a problem, you'll get used to it. I did.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/840439-need-two-more-monitors/#findComment-10495510
