Here are the parts I ordered and already have. I still have time to change them, so are there any things you guys think I should change? I've included the prices I got them for because some parts I got a good deal on during black friday.
CPU: 4770K $280
Cooler: H100i $75
RAM: Gskill Ripjaws 1866MHz $100
Mobo: ROG Hero VI $190
Case: R2 Midi $90
PSU: HX750 $85
SSD: 840 EVO 250GB $150
HDD: 1TB Toshiba $40
GPU: GTX 770 $300
Total: $1310
https://linustechtips.com/topic/84012-need-part-advice/
What's the system being used for?
https://linustechtips.com/topic/84012-need-part-advice/#findComment-1143726
Video editing in Premiere CS6 using DSLR footage, and I also like to game with 3 monitors in surround.
You should've gone cheaper on the mobo + ssd and gotten a 290 instead.
https://linustechtips.com/topic/84012-need-part-advice/#findComment-1143760
I know. As for the SSD $150 for a 250gig was too good to pass, but the mobo also looks overpriced to me considering it doesn't offer anything too special. It does have auto overclock with 4 way optimization which is great for me since I know nothing about overclocking. Do you have any suggestions for a cheaper mobo?
https://linustechtips.com/topic/84012-need-part-advice/#findComment-1143803
There was a seagate 600 240GB frm newegg on sale for $130 a few days ago. $150 for 250GB isn't that much of a deal.
You should be manually overclocking anyway.
Where are you shopping/located?
Hmmn. I don't game that often so a 290 would probably be a bit overkill for me. Do you know of any good 780 deals?
*Says 290 is overkill. Opts for for the more expensive 780*
What?
The 290 is barely enough for nice triple 1080p gaming as is. The 780 has an even harder time and is more expensive.
https://linustechtips.com/topic/84012-need-part-advice/#findComment-1143819
What?
Lol, sorry I confused it for the R9 290X. How long till the non reference coolers come out?
https://linustechtips.com/topic/84012-need-part-advice/#findComment-1143850
Not sure. I've only heard rumors but I'm thinking soon.
At the very least, you can watercool the 290 with a Kraken G10 and a Hydro H55 for less than a 780.
https://linustechtips.com/topic/84012-need-part-advice/#findComment-1143859
Really? So all of that would be cheaper than $500?
Depends where you're shopping. After all, the 780 is already more than $500 after taxes and other fees.
The 290 + Kraken G10 + H55 (Or any other compatible cooler) should be around the same price as the 780.
https://linustechtips.com/topic/84012-need-part-advice/#findComment-1143885
