Anyone know what this sound is, drives me crazy.
IMG_2055.MOV
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/839687-weird-sound/
Sounds like something is rattling/brushing up against a fan.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/839687-weird-sound/#findComment-10484675
Sounds like a fan with a bad bearing. Sometimes it's a fan touching a loose peace of plastic causing it to vibrate. Finding which fan it's coming from shouldn't be too hard.
https://linustechtips.com/topic/839687-weird-sound/#findComment-10484687
Welp sounds like power supply so rip
https://linustechtips.com/topic/839687-weird-sound/#findComment-10484693
If it's the PSU fan it's not the end of the world. It's not recommended due to the beefy capacitors but you can replace the fan inside the PSU. You just have to be careful.
Also some wire splicing may be required so you'll need a sacrificial fan.
https://linustechtips.com/topic/839687-weird-sound/#findComment-10484699
OP: Be careful here, as in you could literally die if you aren't.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
https://linustechtips.com/topic/839687-weird-sound/#findComment-10484809
hmmmm.... lol
https://linustechtips.com/topic/839687-weird-sound/#findComment-10485213
