i made a new pc and it keeps on turning on and off byitself i have not installed any bios or stuff like that(it hasnt given me a chance to see anything)it stays on for 12 secs and turns off and this process repeats.I took everything out and tested it with the motherboard,cpu,cpu cooler and ram still the same result
btw i may have but too less thermal paste on but it has been on long enough to heat up
https://linustechtips.com/topic/839572-help-new-pc-issue/
So its failing to boot based on something not clearing. So reseat all the components, make sure all power cables are plugged in, then see what it does and get back to us.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/839572-help-new-pc-issue/#findComment-10483423
 i wanted to ask could this be a hardware issue by the way i have
i5 7600k
gigabyte z270x ultra gaming
cyroig h7 cooler
thermal take 530w
https://linustechtips.com/topic/839572-help-new-pc-issue/#findComment-10483428
10 minutes ago, desperate wannabe pc gamer said:
one more question could this be a hardware problem btw the bottom right of my motherboard blinks whlie this is happening if that has any significance
check ur motherboard user Manuel, it might have some explanation.
use one stick of RAM and try all the RAM slots.
https://linustechtips.com/topic/839572-help-new-pc-issue/#findComment-10483495
