Logitech Mice
8 members have voted
  1. 1. Which mouse should I go with
    • Logitech G403
      4
    • Logitech G Pro
      1
    • Logitech G102
    • Logitech G402
      3
It's little bit more complicated. What is your palm size? What is your grip (palm, fingertip, claw)? I'm currently using a G PRO and while I loved it at the beginning, I'm starting to hate it now. I can't hold the mouse comfortably, so I'm constantly re-gripping the mouse. Unless you have very small hands, I would suggest that you stay away from the G PRO.
The best choice would be the G403, just be careful, a lot of people don't like the rear hump. It depends on how you hold your mouse. If you really like the G PRO shape, buy a G203 instead, much cheaper, non-braided cable (which is a plus, because the G PRO has a really stiff braided cable).
Love, D.Va.
https://linustechtips.com/topic/839535-help-me-choose-a-mouse/#findComment-10483102
Length of hand is 19 cm, width is 8 cm. Im a Claw/fingertip hybrid. Do you have any recommendations on other mice?
https://linustechtips.com/topic/839535-help-me-choose-a-mouse/#findComment-10483126
G403 should be fine then, I guess. The new Sensei/Rival 310 is also a good mouse (same internals, different shape)
Rival: https://steelseries.com/gaming-mice/rival-310
Sensei: https://steelseries.com/gaming-mice/sensei-310
Love, D.Va.
https://linustechtips.com/topic/839535-help-me-choose-a-mouse/#findComment-10483784
If you do claw or fingertip, the G-pro might be the best option for FPS due to the wight savings and sensor. That style grip probably will keep the smaller size of the G-pro being as big of a factor. Personally, I went with the G403 Wireless. I love the shape, its comfortable for long gaming and work sessions. I find that the side buttons aren't mushy and have good response, the scroll wheel button can seem a little stiff at first but I got used to it and enjoy it.
My recommendation goes to the G403 if you're looking for a more rounded, do all mouse and the G-Pro if its strictly gaming. Hope this helps!
CPU: Intel Core i7 8700k 3.7Ghz MOBO: AsRock Z370 Extreme4
RAM: Corsair Vengeance (4x4) Storage: Crucial MX300 275Gb | WD Blue 1Tb
GPU: XFX RS RX480 8Gb Case: Corsair 270R PSU: Seasonic Focus+ 750w
Monitors: HP 22cwa | BenQ BL2420PT  Cans: ATH-M50x
https://linustechtips.com/topic/839535-help-me-choose-a-mouse/#findComment-10483877
Im Looking at the G403 and the Deathadder. Im leaning more towards the deathadder
https://linustechtips.com/topic/839535-help-me-choose-a-mouse/#findComment-10485927
It really comes down to personal preference, which type of grip you use and of course the size of your hand.
I'd suggest heading to an electronics store that has mice on display and trying them out, then going with the one that best fits your hand.
https://linustechtips.com/topic/839535-help-me-choose-a-mouse/#findComment-10489604
If you use a claw/fingertip grip style, I would say categorically the death adder and g403 will be a bad idea. They both have a pretty prominent slope down towards the right hand side of the mouse in the mid section. They are great mice, but Im pretty sure your grip style would change as you got used to these mouse (not neccissarily a bad thing).
As a claw/fingertip gripper myself, I find the ambidextrous, or symetrical mice a must. G203 is really nice, although maybe a little wide towards the front for my liking, and I found it pretty hard to stay in full control of the mouse when flicking around at high speeds. That said, g203 seems to be the best mouse around in terms of value, and from what you've said thats the one I'd recommend. I'd heavily encourage checking out the ZA series from zowie, and also abyssus v2 from razer though.
Great resource for mouse info: https://www.youtube.com/channel/UCGJaDZC7PChgd-XMwcbZkiw
https://linustechtips.com/topic/839535-help-me-choose-a-mouse/#findComment-10489882
Thanks
Yes I was about to make the call and get the abyssus v2 from razer then saw it had no side buttons. Rocket jump ninja is awesome when it comes to his stuff and Im waiting on the basilisk review
https://linustechtips.com/topic/839535-help-me-choose-a-mouse/#findComment-10490845
