I have the phantek p400s, on their site it says that the cpu cooler clearance is 160mm. A lot of the higher end air coolers have a height of 160mm. I’m worried that I may have some issues because I’m cutting it so close. Will I be fine with a 160mm cooler if I have 160mm of clearance or should I go for something smaller
| CPU Intel I7 6700K | Motherboard Asus ROG Maximus VIII Hero | RAM 16GB Corsair Vengeance LED 2666Mhz | GPU MSI GTX 1080 Ti Gaming X + NZXT Kraken g12 w/ NZXT Kraken x52 | Case NZXT h440 | Storage 500GB Samsung 960 Evo, 2TB Samsung 850 Evo | PSU EVGA Supernova G2 750W | Cooling Thermaltake Water 3.0 Ultimate |
https://linustechtips.com/topic/839357-will-my-cooler-fit/
Yes, you'll be fine. There's usually a bit more room than stated.
https://linustechtips.com/topic/839357-will-my-cooler-fit/#findComment-10481291
