any help would be greatly appreciated i can make the lcd panel work outside the case using the lcd power board and control panel however i would like to be able to power the control board and panel using a molex connector. if anyone knows where i need to add power and ground or how to test would be a big help. other question would be how to power some led lights using a molex as well
the images show the power board wires and the pin out diagram to the left where should i apply 5v and ground on the control board?
the last pic is the lcd panel already mounted in my case
https://linustechtips.com/topic/839264-lcd-case-window-displaylike-snowblind/
From the looks of things it is 5V VCC, I would ideally probe the pins from the power supply module (DC side) to get the correct values very carefully not to touch or short anything on the AC side.
A bit of an update I have made the screen work I have displayed windows on it however I am getting a bit of a stutter in the case. I removed it and am trouble shooting plus I need to remove the antiglare coating but all in all so far so good
