I took the front off of my Tt core v1 and hit the gigantic front fan that comes with it and now im pretty sure it wobbles the whole case or am I just imagining this? If that is the case if I l leave the fan their will it wreck itself and eventually I will have to replace it? this is kinda worrying because it is my main airflow for this case and I let my computer run all the time
https://linustechtips.com/topic/838896-case-fan-broken/
Don't use a fan with a broken blade it's unbalanced so that will cause vibration just leave the system open so there is adequate airflow in the meantime before you replace it with another fan.
https://linustechtips.com/topic/838896-case-fan-broken/#findComment-10475970
