 For several of months my game has been crashing several of times.I even re-installed windows 3 times,changed the RAM,changed the PSU and still no success. I then decided to lock my game at 60 fps and the GPU degrees fell by 20° and  and the GPU usage also decreased. I played a good 3 hours and my game didn't crash, normally my game would crash within the first 30 min. This result shows that the game crashes when the GPU usage is high or when the GPU temp is high.So what do you think i should do next?
https://linustechtips.com/topic/838505-help-meh/
Full specs?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/838505-help-meh/#findComment-10471702
PC Specs:
GPU: GTX 670
CPU: Intel i5-4460 3.20GHZ
CPU Heat Sink: Hyper 212 EVO
Motherboard: Gigabyte GA-H81M-DS2V
PSU: 700W evga power supply
HDD: WD Blue 1TB
RAM: 8GB
SSD: 120gb SanDisk
https://linustechtips.com/topic/838505-help-meh/#findComment-10471704
2 minutes ago, GGMINION said:
PC Specs:
GPU: GTX 670
HDD: WD Blue 1TB
RAM: 8GB
SSD: 120gb SanDisk
probably GPU going out or being forced to handle to large of a workload. Id say start there; try a different one if possible, or the iGPU if you can
https://linustechtips.com/topic/838505-help-meh/#findComment-10471718
