so ive been playing overwatch for a good 4 days or so..
and i get 150+ fps in everyday and everygame,
but today i woke up.. turned my pc on and wanted to game as usual..
but i started getting 60-70 fps even on the same maps, didnt change any settings, and didnt change gpu settings either.
i even have my gpu overclocked and the gpu usage isnt even maxed out.. so it makes no sense,
my gpu is a GTX 1060 G1 Gaming by gigabyte (6GB).
please help me out, as i really need the extra frames..
and i tried removing the overclock on my gpu, but it still gave me 60-70 fps..
https://linustechtips.com/topic/837830-low-fps/
Just now, NewReborn said:
Turn off the PC, shut off the PSU. Wait for 5 minutes and start it up again if that doesn't help, clearing CMOS is another thing you could try.
do i need to wait like exactly 5 minutes? like.. will doing it like 6 or 4 minutes not cold boot the pc?
https://linustechtips.com/topic/837830-low-fps/#findComment-10465155
You need to do it long enough to drain any reservoir capacitors in the PSU so the system is entirely un-powered and definitely reset
Yours faithfully
https://linustechtips.com/topic/837830-low-fps/#findComment-10465168
do i wait until the pc shuts down completley? (sry that its a silly question, but its my first time trying to cold boot)
https://linustechtips.com/topic/837830-low-fps/#findComment-10465171
Yes, the idea of power cycling is to cold boot the PC so that the machine will be completely reset (not the BIOS but the power stuff) so any errors in it will go away. A cold boot is just booting after the PC was turned off or unpowered.
Yours faithfully
https://linustechtips.com/topic/837830-low-fps/#findComment-10465176
thank you so much, i will try that immediatley
https://linustechtips.com/topic/837830-low-fps/#findComment-10465178
1 minute ago, Versti said:
it didnt work.. sadly.. my cpu is the ryzen 1700 and not overclocked
In this case, if neither of those options worked, I'd consider looking at the OS or maybe there is some kind of virus. Do the drivers show any kind of error or issues in the control panel?
Yours faithfully
https://linustechtips.com/topic/837830-low-fps/#findComment-10465208
i meant that the cold boot didnt work, but about the ddu.. how do i start it..? it extracts to /downloads , and there's no .exe anywhere in there
EDIT: nvm, found where to start DDU from
https://linustechtips.com/topic/837830-low-fps/#findComment-10465215
and drivers are working prefectly, "Drive Status: Ok
All Drives are working properly.".
https://linustechtips.com/topic/837830-low-fps/#findComment-10465219
27 minutes ago, Lord Nicoll said:
If that does not work, try a programme called DDU to remove the drivers and then reinstall them. Also what is your CPU and is it overclocked too?
ddu brings up a notification about me booting into safe mode or something, what do i do?
https://linustechtips.com/topic/837830-low-fps/#findComment-10465227
after using DDU and reinstalling my Gigabyte Xtreme Gaming software, my gpu stopped getting recognized in the software..
not getting recognized even by EVGA Precision too..
https://linustechtips.com/topic/837830-low-fps/#findComment-10465258
2 minutes ago, NewReborn said:
Gigabyte's software is NOT a driver. It's bloatware and it was likely what was causing the problem to begin with. You have to install the driver located on Nvidia's website. And remove Gigabyte's garbage
ill try.. thank you... cuz even after DDU, i still get 60-80/70 fps
https://linustechtips.com/topic/837830-low-fps/#findComment-10465292
Currently you're using the Microsoft basic display adaptor drivers. You'll need to download the correct driver off Nvidia's website. Also Gibabytes software blows massively, of all the software, it's probably the worse from a GPU AIB maker.
This doesn't really mean anything. There could have been an unknown setting changed in the BIOS or some part of it broke that doesn't show up. It's still one of the first things to do when there is a performance change.
Safe mode is part of windows, it boots and loads the OS without any drivers, using only the basic windows ones. It's easier to uninstall a driver when it's not being used.
Yours faithfully
https://linustechtips.com/topic/837830-low-fps/#findComment-10465343
i used DDU, installed everything i needed... uninstalled everything that has to do with gigabyte, i still get 60-70 fps..
https://linustechtips.com/topic/837830-low-fps/#findComment-10465357
fml.. apparently changing quality from ultra to epic and then back to ultra helped boost the fps back to 170.. FUCK MY LIFE, guys im sorry for wasting your time, please forgive me.. it wan never my intentions.. but thank you for your help about the gigabyte stuff and sht.. appreciated..
@NewReborn @Lord Nicoll
https://linustechtips.com/topic/837830-low-fps/#findComment-10465367
That's cool, it must have been a game setting that got changed maybe, no worries.
Yours faithfully
https://linustechtips.com/topic/837830-low-fps/#findComment-10465451
