I have a lot of case fans and I want a good fan hub which I can hide and connect all the fans to. I found the Thermaltake AC-023-AN1NAN-A1 Commander FP Hub which seems good but the reviews are bad. Any suggestions?
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/837809-fan-hub/
As long as the hub is plugged into a PWM hearer for the hub's input signal and your fans are 4 pin PWM fans they will all be group controlled.
https://linustechtips.com/topic/837809-fan-hub/#findComment-10465040
