Hi,
Need to replace the battery in my Note 4. Had the phone for over 2 years now and the battery is basically dead.
So found the following 2 on Amazon:
Battery 1 - RAVPower
Battery 2 - Anker
I've heard of Anker before, so thinking of that one. But just wanted to know if anyone has had any experience buying from either one or suggest one.
Kind regards
Gaming Rig:
CPU: AMD Ryzen 3600X @ 4.1GHz All Cores - Ram: 16GB Corsair VENGEANCE - GPU: 5600XT MSI Gaming X - Storage: Samsung EVO 840 250GB - 2TB Seagate Drive OS: Win10
HTPC Rig:
CPU: i5 6400 - Ram: 16GB - GPU: 970 GTX - Storage: 120 Kingston SSD & 2x 1TB Seagate Drive OS: Win10
https://linustechtips.com/topic/836355-note-4-battery/
Go with anker i have never heard of RAVpower also anker has alot more reviews
My Personal Computer
CPU: AMD - Ryzen 5 1600 3.2GHz (OC 3.8) 6-Core Processor
Cpu cooler DEEPCOOL Gamer Storm CAPTAIN 240EX WHITE
Motherboard: MSI - B350 TOMAHAWK ARCTIC ATX AM4 Motherboard
Memory: Corsair Vengeance DDR4 3000MHz RAM 8x3
Storage: SAMSUNG 850 PRO 2.5" 256GB SATA III
Storage:SAMSUNG 850 PRO 2.5" 500GB SATA III
Video Card: RTX 2060
Case: NZXT - S340 Elite (White) ATX Mid Tower Case
Power Supply: EVGA 550 B3 550W
Peripherals
Monitor: Acer XF240H 24" TN Free-Sync ,144 Hz
Keyboard: Corsair k95 RGB platinum
Mouse: Razer basilisk
Headset: Hyperx cloud alpha pro
https://linustechtips.com/topic/836355-note-4-battery/#findComment-10448588
I noticed that, And thought the same just wanted to double check :)
Gaming Rig:
HTPC Rig:
https://linustechtips.com/topic/836355-note-4-battery/#findComment-10448597
Anker, RavPower is okay but Anker is where it's at with batteries IMO.
Gaming Desktop - AMD Ryzen 7 5800X, MSI MPG B550 Gaming Plus, 32GB Cosair Vengenace LP 3600mhz, EVGA RTX 3070 XC3 Ultra,  Sabrent Rocket 4 1TB NVME SSD, Crucial P3 4TB NVME SSD, 4TB Mass storage, EVGA 750W G2, NZXT H9 Flow
https://linustechtips.com/topic/836355-note-4-battery/#findComment-10448680
I've had RAVPower stuff, it's great. I've also had Anker.
Realistically, they're sourced from the same supplier. Neither of these companies produces batteries.
Pick the one you like the look of more.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/836355-note-4-battery/#findComment-10450219
