PSU model?
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/835690-600-build-help/#findComment-10442148
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/835690-600-build-help/#findComment-10442149
1 minute ago, GDRRiley said:
id rather use 2 sticks for dual, I will probably just get some used ddr4 depending on how much i can cut the cost.
https://linustechtips.com/topic/835690-600-build-help/#findComment-10442158
why then your stuck with 8gb.
https://linustechtips.com/topic/835690-600-build-help/#findComment-10442159
Not worth it. You should avoid using 4GB DIMMs as much as possible these days. Plus, the performance difference with dual channel is minimal, you're MUCH better off getting cheaper, faster RAM, especially with Ryzen.
CPU: AMD - Ryzen 3 1200 3.1GHz Quad-Core Processor  ($109.88 @ OutletPC)
Motherboard: Asus - PRIME B350M-A/CSM Micro ATX AM4 Motherboard  ($71.98 @ Newegg)
Memory: G.Skill - Aegis 8GB (1 x 8GB) DDR4-3000 Memory  ($71.99 @ Newegg)
Storage: Crucial - BX300 120GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Storage: Western Digital - RE4 1TB 3.5" 7200RPM Internal Hard Drive  ($41.95 @ Amazon)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB GAMING Video Card  ($269.98 @ Newegg)
Case: Deepcool - D-Shield ATX Mid Tower Case  ($29.99 @ SuperBiiz)
Total: $655.76
It's $30 more expensive, however, I do not recommend the GTX 1060, that's just a placeholder. What you should do, is buy a used GTX 970 or GTX 980 since you can get a 970 for less than $200 ez, or a 980 for less than ~$240. Either of these will get you back down to the same price as the original system you were looking at AND this has a better motherboard, as well as an SSD and faster RAM. If you manage to get a GTX 980 for <$220 or get a GTX 970, then you can swap the Deepcool case back to the CM N200, if you want.
Intel Core i7-4790k @ 4.7GHz | Asus Maximus VII Hero | NZXT Kraken X61 | 2x8GB Corsair Vengeance Pro(Red) @ 1866MHz | 2TB Seagate Barracuda | 250GB Samsung 850-EVO | 2- way SLI Asus Strix GTX 970's @ 1500MHz | EVGA 750W G2 | NZXT H440(black/red) | 3x120mm Sharkoon Shark Blade fans(red) | 3x140mm Be Quiet! Pure Wings 2 fans |
https://linustechtips.com/topic/835690-600-build-help/#findComment-10442253
Isn't that the card with overheating issues?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/835690-600-build-help/#findComment-10442263
Not as far as I'm aware. Again though, I didn't recommend the GTX 1060, it's a placeholder.
https://linustechtips.com/topic/835690-600-build-help/#findComment-10442266
Grain of salt required reddit post?
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/835690-600-build-help/#findComment-10442269
Uh, yeah, idk how much I believe that. He links a video but it doesn't even show the GTX 1060 throttling at any point, so he's making claims without actually showing any proof of thermal throttling. Useful to note though, in case I hear/see anything more from someone who owns the card. Regardless though, I'd recommend a used GTX 970 or GTX 980 for this budget anyway, and even if I WAS going to recommend a GTX 1060, I'd have probably recommended a different one lol
https://linustechtips.com/topic/835690-600-build-help/#findComment-10442289
yeah RX 580s are somewhat back anyway
Full Specs
Helios EVO (Main):
Delta - Laptop
https://linustechtips.com/topic/835690-600-build-help/#findComment-10442406
