Laptop start-up issue
Xiauj
Hey guys.
Alright so, I recently got given an old (..very old) laptop that I'm gonna see if I can start up and so far... no luck and I need some suggestions, lol.
So, the power button turns the laptop on fine and stays Green but then it will just go insanely quiet but still be turned on, I think/hope. The screen however, displays NOTHING at all; just a black screen. The person did give me a charger so yes it should be charged hopefully. The optical drive on the side of the laptop opens and closes so I would assume the laptop is still on at this point, yet I still can't get the laptop to display anything to a monitor via VGA Cable. Is there any type of Key-Combo that would perhaps do the trick?
I also tried using passive adapters converting from VGA to DVI-I to HDMI because the monitor wouldn't pick up anything on the VGA Channel which I thought was odd and with those adapters, still nothing being displayed via HDMI.
Anyone got any suggestions? I'm not really sure at this point.
Thanks
-Xiauj ^_^
Hey I'm Xiauj ^_^ Wassup :3
On another working computer you could create a bootable USB drive running a Linux distro, boot to that on the old laptop and see if the screen displays. This could tell you if it is a hardware issue or an issue with the OS on the boot drive
Edited by An angry badger
Correcting a spelling mistake
The CD drive will open whenever the device has power, it has no bearing on whether it is functioning properly or not. If the device will not output to display, it is likely not POSTing. Unless you want to invest money in replacing the screen (likely to no avail), I would recycle it. If it has a hard drive activity LED, you can watch that. If it blinks once or twice when you turn the laptop on, then never again, you have a dead device
Good luck!
  • CPU
    Intel Core i7-7820X @ 4.2GHz
  • Motherboard
    Asus Prime X299 Deluxe
  • RAM
    32GB G.Skill TridentZ RGB DDR4
  • GPU
    GTX 1080Ti FE
  • Case
    Phanteks Enthoo Evolv ATX
  • Storage
    500GB 960 Pro SSD, 240GB PNY SATA SSD, 3TB WD Red NAS
  • PSU
    Corsair RMx Series, RM850x
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
    Razer BlackWidow Chroma "Clicky"
  • Mouse
    Razer Super Mega Black Mamba of Death 9000DPI
  • Sound
    Logitech Something with a broken bass adjustment knob so it's always rupturing spleens
  • Operating System
    NSA-Approved version of Windows 10 Pro
Just now, An angry badger said:
On another working computer you could create a bootable USB drive running a Linux distort, boot to that on the old laptop and see if the screen displays. This could tell you if it is a hardware issue or an issue with the OS on the boot drive
Not if he doesn't get a display. I'm assuming no BIOS screen?
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
Does the laptop have hard drive activity lights?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
I have no knowledge about Linux in the slightest xD Though saying that, I do want to try it out at some point, I hear there is a ton of Distros.
But tbh, this is a insanely old looking laptop and I doubt Linux would be of use atm. Mainly want to get it to the desktop for now.
Yeah I think it has power going to it because I have it on atm and the power button is lit up green but as mentioned, it's insanely quiet, like 100% quiet.
Where would I find this LED? A LED on the laptop itself or..?
Oh and I probably should have mentioned this before but I forgot, it doesn't even show a logo/loading-bar when I press the power button, I was gonna add at the end of my OP that I think it could be a dead screen/panel but yeah I dunno atm. If no logo/loading-bar, could that be its not posting?
I dunno if I can get in the BIOS either due to the screen not turning on.
Where would I find that? :P
EDIT: There is 2 lights/LEDs on the front of the laptop, one for the battery and one has like a lightbulb symbol
Edited by Xiauj
I don't know, do you see any? I can't see through your eyes...
Main System: Phobos
I just edited that comment, sorry lol
I see 2 LEDs as described above
The icon would look kind of like a stack of CD's. It sounds like the laptop isn't POSTing at all, based on the fact that the fans are going silent.
Is there an Intel/AMD sticker on it? Any indication of operating system? Just want to get a general idea of it's age.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
The one on the far right is generally what it would look like.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
Well as mentioned its a very old laptop and unfortunately, I do not know the specs but it has an AMD Turion 64 CPU xD and it also has Windows XP xD So ya, a very old but not ancient laptop. It's an Acer laptop.
I also cannot find any symbol like the far right one unfortunately :(
The laptop doesn't have that symbol at all.
Any beeps or other noises once you turn it on?
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
I don't hear any beeps when pressing the power button, no. It begins to start up when I press the power button and it sounds like a fan is spinning I think, but then it just goes mostly quiet, aka very quiet. It still sounds like the PC is on though. To add onto that, yes the power button is still green after doing so.
I can just about hear the fan on the bottom/underside of the laptop with my ear right next to it (The laptop).
Sorry mate, sounds like she's toast.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
:( Sure it might not be a dead screen/panel or a dead HDD maybe..?
Anything else at all that I could try?
The computer isn't POSTing, so it's either the CPU, GPU, RAM (you can try replacing/removing that temporarily), or motherboard.
What brand is it? Assuming it's a Dell, you *should* hear a beep code when you power it on indicating a successful POST. Also, fans on older machines typically ramp up quite loud as a self test when you first power the machine on. Is it doing that? Even if it's a dead display, you'd get a better ROI using it as a self defense tool.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
If you're feeling adventurous you can remove everything that isn't necessary, for shits and giggles. Pull out all the memory, the hard drive, the wireless card, the battery, and any devices/cables/cords plugged in besides the power cord.
  • CPU
  • Motherboard
  • RAM
  • GPU
    GTX 1080Ti FE
  • Case
  • Storage
  • PSU
  • Display(s)
    3x 1080p Garbage
  • Cooling
    Fully Custom EK :D
  • Keyboard
  • Mouse
  • Sound
  • Operating System
