Hey guys, so basically It's my first build and I'm currently trying to install windows 10 however when trying to install on my SSD i get the message that I cannot use that disk as it is MBR and not GPT? As i said I'm a first time builder and new to this and have no idea whats going on con someone please help?
https://linustechtips.com/topic/834467-help/
1 minute ago, NinJake said:
Normally to my knowledge windows should install whether it's MBR or GPT... You'll have to reformat the drive as GPT if that's what it really wants. You can use a windows recovery disk to launch the command prompt if you have one laying around.
Ive gone into the command prompt but when i try to select the disk it just states that the disk is not valid?
https://linustechtips.com/topic/834467-help/#findComment-10429619
6 minutes ago, TheGlenlivet said:
https://www.windowscentral.com/how-clean-and-format-storage-drive-using-diskpart-windows-10
If you can get to the command prompt can you follow the instructions in the link?
THIS WORKED!!!
Thanks a lot man total lifesaver
https://linustechtips.com/topic/834467-help/#findComment-10429725
