AIO Cooler question
Go to solution Solved by NonanonymousCarl,
Well the Fractal got back to me, leaving this here if someone else has this identical problem.
Thank you for contacting us here at Fractal Design. We recommend that the power cable be connected to the CPU fan header.
Best Regards,
Fractal Design Support
So new Threadripper system is complete minus waiting on an RMA'ed video card, cable management and one other small issue. I bought a Fractal design Celsius s36 and the last step in the manual is to connect it, fine, save my mother board an MSI Pro Carbon x399 has a cpu fan header and a water pump fan header and the instructions just say to connect it :(. What header should I choose cpu fan header or Water pump fan header or does it matter? Also is it fine to run multiple case fans from one motherboard fan header, I am pretty sure I remember I can with a splitter, but it's been since 2011 since I build a fresh build, as the other system was a 8 core xeon that just needed minor updates time to time.
https://linustechtips.com/topic/834429-aio-cooler-question/
Just connect your water pump to the water pump header. If you have a fan hub (Which it looks like you do according to Fractal Design's website) then connect all the fans into the header on the radiator, and run the connection from the radiator into the CPU fan header.
"The only thing that matters right now is that you're here, and you're safe."
https://linustechtips.com/topic/834429-aio-cooler-question/#findComment-10429266
6 minutes ago, Katsunaka said:
Connect it to your water pump header. So your mobo can control thr speed of the water pump based on temps.
As for the fans, idk.
Most AIOs pumps are not controlled by the fan header (not sure about the s36 though) so that wouldn't matter. They're usually controlled by a USB connection, you want the header to give 100% power all the time, not be modulated. I connect my AIO to the CPU header to avoid "no CPU fan" errors (which you can just disable in the BIOS if you prefer), and so the built in system shutdown can be sensed if the mobo senses the AIO has failed.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/834429-aio-cooler-question/#findComment-10429282
Except with water cooling you don't want the fans controlled by the CPU temp (which is what the CPU header would do) you want it controlled by the water temp. Otherwise you're ramping up when it doesn't need to (if the water isn't hot then there's no reason to increase the speed), and the fans slow down when CPU temp drops even if the water is still hot after an expended load.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/834429-aio-cooler-question/#findComment-10429288
Then the question would be how does the integrated hub on the radiator work? It says there's a concealed cable so they're not very clear in whether it's being controlled VIA the pump or if there's a separate cable.
https://linustechtips.com/topic/834429-aio-cooler-question/#findComment-10429298
Not sure about that specific AIO. I assume the built-in hub controls the fans based on the water temperature when set to "intelligent mode". If there isn't some sort of USB connector on the AIO for user control, then maybe the PWM mode is controlled by the CPU temp but that seems like poor design since like I said, water cooler curves should not be based on CPU temp but should be based on water temp.
My AIOs have a USB connection and I control the fans and pump via the software.
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/834429-aio-cooler-question/#findComment-10429312
There is an "auto" and a "PWM" setting for the cooler so I assume then by the above I t should be on the CPU header or the Water Cooler header for PWM? I don't think I want to try "auto" with such a hot chip and one that I will be rendering 3d on for hours.
https://linustechtips.com/topic/834429-aio-cooler-question/#findComment-10429321
So I actually watched a video from JayzTwoCents and I think in this case it would benefit you if you watched it to understand what everything does and why he runs the fans into the header and how the Auto / PWM function works.
Mods: Sorry in advance if I'm not allowed to link this video.... Seems Linus didn't actually review it. :/
https://linustechtips.com/topic/834429-aio-cooler-question/#findComment-10429337
simple....run pump off any source that will run it @ 100% all the time period..... fans can be run from cpu header but you will have to adjust the fans curve so there not going crazy when the cpu temp goes up, the fans can be set to around 40% 95% of the time then up the curve at the end when temps go above 70c or so, mine is running 40% and cant hear them they hardly ever ramp up coz there super lound when they do my idle temps are 28c and never above 75c no matter what I'm doing, with the h115i the connection to the pump header is a single wire on a 4 pin connection and is ONLY used as a moniter for pump speed, not sure what the Celsius has
I7 7700K @5.0ghz, Asus Z270-P, Corsair H115i, hyperX 16gb, Asus duel 1070, Nzxt H440
https://uk.pcpartpicker.com/list/ZTsYD8
https://linustechtips.com/topic/834429-aio-cooler-question/#findComment-10430443
Best Regards,
https://linustechtips.com/topic/834429-aio-cooler-question/#findComment-10432740
