What? You need Android?
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
Just now, BloodyWaters said:
I'm confused.
I need any mini project for my mobile which is running on Android. The apk which we get frm google play store.
So i need any  Android apk for my Android Mini project.
Free source code won't do the job.
If you use someone else his/her source code you'll likely need to add somewhere in the code where you get it from.
If you don't and your teacher finds out you basically stole the code and committing plagiarism which can get you in a LOT of trouble.
Small list of possible consequences: instantly failing for the subject that gave you the task. instantly failing your semester requiring to re-do ALL subjects from that semester. Getting kicked out of school. Charging one or multiple semesters/years you completed succesfully as invalid requiring you to do them again.
It's nasty, go outside and buy a book or go to a website like lynda.com and get a course from there.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
