So I have a NZXT S340 case and I'm planning on upgrading my AMD stock Wraith Spire Cooler, that came with the Ryzen 1600 CPU, to a Corsair H60 water cooler. However, I have 2 front intake fans, 1 rear, and one top exhaust fan at the moment. I've been reading online and it's advised that the H60 Water cooler be setup as an intake fan to bring in cool air into the CPU. So my question is, should I replace my rear or top fan with the water cooler that I have coming in? Or should I just set the water cooler fan as an exhaust fan seeing that I already have 2 intake fans coming in from the front of the case. I'm having a hard time coming up with a good solution and any useful advice would be greatly appreciated. Thank you!
https://linustechtips.com/topic/833404-pc-fan-flow/
When you say "the H60 Water cooler be setup as an intake fan to bring in cool air into the CPU", remember that airflow won't affect it because it is covered by a water block. It depends what fits best in the case. I haven't worked in that case before but what ever works for you.
i think your looking for a quieter solution because I built a system which had the same cpu and it can ramp up the fan speed a lot which is quite noisy. Especially when gaming. A water cooling solution is also better for longevity of cpu and overclocking (depending on your motherboard).
TLDR: if you already have fans in the front, put it in the back or top and vice versa
PC Specs:
CPU: Intel Core i7-12700K 3.6 GHz 12-Core
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler
Motherboard: Asus ROG STRIX Z690-E GAMING WIFI ATX LGA1700
RAM: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5200 CL40
Storage: Boot Drive: Samsung 960 Evo 250GB M.2 NVMe SSD
               Other Storage: Mass Storage: Western Digital Caviar Blue 1TB 7200 RPM, Western Digital Caviar Blue 2TB 5400 RPM, Scratch Disk: Intel X25-E SSDSA2SH032G1 32GB SATA II SSD, Backup Drive: Seagate ST3160318AS 160GB HDD
GPU: Asus GeForce RTX 3080 Ti 12 GB ROG STRIX GAMING OC
Case: Corsair 5000D AIRFLOW ATX Mid Tower
PSU: Silverstone Strider Platinum S 1000 W 80+ Platinum Certified Fully Modular ATX
OS: Windows 11 Pro 64-Bit
Monitors: Primary: Samsung S34E790C 34" 3440*1440 60 Hz UWQHD; Secondary: LG 34UM58-P 34" 2560*1080 75 Hz UWFHD; Tertiary: BenQ GL2460 24" 1920*1080 60 Hz FHD
Keyboard: Corsair K70 Mk. 2 RGB Gaming Keyboard - Black
Mouse: Corsair M65 Pro RGB FPS Gaming Mouse - Black, Logitech MX Master 3
Headphones: Corsair VOID PRO Surround Cherry 7.1ch
Speakers: Logitech Z213 7W 2.1ch
Laptop:
Asus Zenbook Pro 15 (UX535Li-E2018T) with Intel Core i7-10750-H 12MB @ 2.60GHz (Turbo @ 5.0 GHz), 16GB (2 x 8GB) DDR4 2933 MHz SODIMM and Intel(R) UHD Graphics; NVidia Geforce GTX 1650-Ti with Max-Q Design, using WDC NVMe PC SN730 SDBPNTY-1T00-1102, on a 96-Wh battery
NAS Specs:
Make & Model: QNAP TS-1277
CPU: AMD Ryzen 5 1600 @Stock
Hard Drives: x8 WD Red 2TB
SSDs (2.5"): x1 Samsung 850 Evo 250GB V-NAND (cache drive)
M.2 SSDs: None
RAID Configuration: RAID 6 (excluding SSD)
Total Storage: 12TB
Expansion Cards: None
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10417925
the h60 has been in production for awhile now and what you'll find on the h60 is the inadequacy of the cooling performance. the higher temps will subside until you crank the fan speed to ear-bleeding max. so you'll source a quieter, better performing fan with a more expensive fan. now you'll have an extra added cost, that could have been avoided by purchasing a better cooling system. if you can't run a dual 120/140 (240/280) AIO radiator, then stick to a mid/high-ended air cooler.
the 340 can support a 240/280 in the front and use a single 120 in the rear i/o and call it a day with that. do not install the second 120 in the roof as the balance will go severe negative pressure and you note a more dusty interior.
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10417969
What are your specs and why are you looking at the H60? It's a rather old cooler and there are usually better options available.
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10418002
This is my build right now running on the stock cooler. What cooler would you recommend? I'm looking to overclock up to 4.0 ghz at low temps.
https://pcpartpicker.com/list/qhcGQV
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10418060
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10418061
Do you think this air cooler will be good enough?
https://www.amazon.com/gp/product/B01M6CR4GH/ref=ox_sc_act_title_1?smid=A1K48CS0K3BRLW&psc=1
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10418082
What are your temps? Have you tried oc'ing with the stock cooler?
52 minutes ago, jaytrl said:
Quoting yourself isn't really useful in this case.
A Mugen 5 should be plenty of cooling. The cheaper Kotetsu should also be enough: https://pcpartpicker.com/product/7998TW/scythe-cpu-cooler-scktt1000
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10418191
Got it. I managed to slightly overclocking my CPU to 3.80GHz at 1.36875 Voltage with the stock cooler. How much more do you think I can overclock my CPU with decent temps once I swap out the cooler for the Mugen 5?
Looking for anyone's opinion on what the best Air Cooler is for a Ryzen 1600 CPU for overclocking. I managed to OC my Ryzen 1600 to 3.8M0Hz at 1.36875 Voltz with the stock cooler it came with, but I'm looking to OC the CPU a bit more, hopefully at a lower voltage. I'm also open to AIO cooling systems as well that won't break the bank, but will hopefully perform just as well. I'm open to suggestions and it'll be greatly appreciated. Thank you!
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10418295
Best air cooler in general is the noctua nh-d15.
ASUS Maximus VII Hero | i7 4790K OC 4.8GHZ | 4x8GB 2400MHz MSI GTX 1070 alphacool eiswolf gpx pro
Samsung 850 EVO 520GB + Corsair 525gb + 275gb SSD  2TB Seagate Barracuda | 8TB Seagate Archive
Cooler Master HAF-X 942 | EVGA Supernova 1000W 80+ Platinum | Custom watercooling loop (gpu+cpu)
360mm+180mm rad and 10 fans | Swiftech D5 mcp655-B
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10418358
How much voltage is needed and what temps you get will depend on how well your particular chip oc's. Is that as high as you can go with that voltage?
It's not that great of an oc and you probably can't reach 4ghz with that chip--not many 1600's can. You should be able to hit 3.9ghz with a better cooler.
A better cooler won't really change how much voltage you need for an oc.
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10418384
Ive decides to go with this air cooler:
Noctua NH-U12S SE-AM4
Even if I cant overclock any higher it should bring down temps. Im still hoping to oc a bit more. Fingers crossed.
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10418434
Its good choice. Definitely top tier of 120mm coolers.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10420439
I'd personally recommend against a 120mm AIO, in my experience you can get a better performing air cooler for less. If you're gonna go with an AIO go with at least a 240mm one otherwise you'll be disappointed.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/833404-pc-fan-flow/#findComment-10420464
