AMD + Nivida GPU Driver Problem
Solved by SpaceGhostC2C,
2 hours ago, tjwmagic said:So far, everything is working fine, without the driver installed. I bet Windows decided to install its own driver, IDK how it's working though.
GPUs will always work at a minimum in Windows, the same way they work for BIOS and all the way from POST until the OS loads the driver. You typically can't get the most of them without the manufacturer's specific driver, though.
Have you tried uninstalling any driver automatically installed by Microsoft before proceeding to install the V3900 official driver?
