LED Strip... issue?
Go to solution Solved by W-L,
5 hours ago, sickforthecure said:
Hey guys, I recently bought an RGB Led Strip from Phanteks (it took me a lot to find one in my country) and everything was okay until I saw what you're seeing in the pictures, it belongs to the same strip.
It does work, but my question is, is there any problem if I keep it that way? The thing that covers the leds and the strip is kinda broken/open as you can see but it works perfectly fine.
I'm asking this, not because I'm lazy, but because it took me a lot to find it and it took me a lot as well to get it delivered to where I live in.
That's just a water resistant sleeve they put over the LED strips, and it's not a problem to use it.
https://linustechtips.com/topic/832426-led-strip-issue/
I would guess it's mostly fine, and probably an easy DIY fix if it is a problem
https://linustechtips.com/topic/832426-led-strip-issue/#findComment-10408604
https://linustechtips.com/topic/832426-led-strip-issue/#findComment-10409503
Is there a way to solve it myself? Some transparent tape?
Oh, I didn't knew it was a water resistant sleeve, looks gooey tho, maybe some transparent tape would work as a fix?
Thank you both guys!
https://linustechtips.com/topic/832426-led-strip-issue/#findComment-10410183
Yes some tape or clear adhesive like silicone will work, if you want to cover it back over. In a PC it would be more about dust I guess more than anything else.
https://linustechtips.com/topic/832426-led-strip-issue/#findComment-10410228
I'll cover it with some tape for now until I get some silicone adhesive, that seems the better solution, for now I'll go with the tape, hahahaha, thanks a lot man, again :D
https://linustechtips.com/topic/832426-led-strip-issue/#findComment-10410697
