So I am currently using my m40x's with the angled HM5 pads and I feel like I could just use a little bit of EQ to bring up the bass to really make these headphones awesome. I really love the highs that these have but I just need a little more bass/punch on kick drums (I like a lot of metal/rock music). I use Foobar2000 to listen to my FLAC files and the EQ in there seemed to do the trick but I want to be able to use an EQ when I listen to my tunes on spotify as well. Any ideas here?
https://linustechtips.com/topic/832017-system-wide-eq/
If you are using onboard audio with a realtek chipset you should be able to set a EQ in the realtek control panel.
[GUIDE] LGA 771 Mod for Dell Vostro 220 [GUIDE] LGA 775 BSEL Mod [BUILD] The Mighty Radeon-Powered Dell [VIDEO] Evolution of Intel CPUs
Can you game on an 8-year-old i7? Is the 4-year-old GTX 660 still relevant? Upgrading the HP Pro 3500
Main Rig:
CPU Intel Core i7 4930k @ 4.3GHz | Motherboard ASUS P9X79 Deluxe | RAM Hynix 32GB (8x4GB) 2133MHz CL11 | GPU Gigabyte GTX 980Ti G1 Gaming | Case NZXT Phantom 410 | Storage Samsung 850EVO 500GB, Seagate Barracuda 2TB | PSU Cooler Master G650M (650W) | Monitors x1 Dell U2515H, x2 Dell 1907FP | Cooling Noctua NH-D14 w. x2 NF-F12 iPPC-2000 PWM | Keyboard Logitech G610 ORION BROWN | Mouse Logitech Performance MX | OS Microsoft Windows 10 Pro x64
https://linustechtips.com/topic/832017-system-wide-eq/#findComment-10404103
This is my system and the MOBO I'm working with - where would I be able to tell if I have Realtek? I'm not currently on that PC so I can't check atm
https://pcpartpicker.com/list/R6ykWX
https://linustechtips.com/topic/832017-system-wide-eq/#findComment-10404111
Check the website for specifications: https://us.msi.com/Motherboard/Z170A-GAMING-M5.html
https://linustechtips.com/topic/832017-system-wide-eq/#findComment-10404114
So this is what it says on the product page - where would I go from here to access the EQ on my PC?
Audio
- Realtek® ALC1150 Codec
- 7.1-Channel High Definition Audio
- Supports S/PDIF output
https://linustechtips.com/topic/832017-system-wide-eq/#findComment-10404129
You could try searching "realtek" (without quotation marks) in the start menu. That works for me on my P9X79 Deluxe.
Main Rig:
https://linustechtips.com/topic/832017-system-wide-eq/#findComment-10404143
if all you want is a little more extra bass, you don't need a full EQ. windows has a bass boost setting built into it's own audio settings - and those apply system wide
https://linustechtips.com/topic/832017-system-wide-eq/#findComment-10404163
2 minutes ago, kmathieu2220 said:
Yeah I've tried that - it works fine but not as detailed as I want. Good place to start though so thanks :)
well, most equalizers that come with the audio driver also have only 8 to 10 bands so that's not very detailed either
https://linustechtips.com/topic/832017-system-wide-eq/#findComment-10404196
6 minutes ago, seduce_me said:
Nope. Peace GUI is just an extension to the program. They should be easy enough to use. Check out the links in @Legendarypoet's post above.
I think the GUI is included as part of the default install, rather than needing to download it separately.
https://linustechtips.com/topic/832017-system-wide-eq/#findComment-10404212
You can also use something like VB-Audio Banana which has a fully editable built-in EQ. http://www.vb-audio.com/Voicemeeter/banana.htm
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/832017-system-wide-eq/#findComment-10413338
