CX450 is pretty decent for $22 after rebates. the 1050ti is the only choice at that price range, the RX 4/570s are gone with the mining craze. you can try finding a used gtx 970 for better performance. also, you don't need that thermal paste.
https://linustechtips.com/topic/831999-power-supply/#findComment-10403877
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor  ($78.89 @ B&H)
Motherboard: MSI - B250M PRO-VD Micro ATX LGA1151 Motherboard  ($51.98 @ Newegg) i'm guessing you picked this for the mouse. if not get the B250m-ds3h.
Memory: Crucial - 8GB (1 x 8GB) DDR4-2133 Memory  ($62.98 @ OutletPC) the ram you picked wasn't in stock.
Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card  ($142.29 @ Amazon) takes 1-4 weeks to ship btw.
Case: VIVO - CASE-V00 ATX Mini Tower Case  ($27.99 @ Newegg Marketplace)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply  ($21.98 @ Newegg)
Total: $386.11
Generated by PCPartPicker 2017-09-07 09:48 EDT-0400
https://linustechtips.com/topic/831999-power-supply/#findComment-10403890
1 minute ago, SavageBadger said:
Is there any card you could recommend me? im trying not to go over $410
nothing better that'll fit in your budget. either get the 1050ti or a used 970.
https://linustechtips.com/topic/831999-power-supply/#findComment-10403912
