Hi, Im hosting a LAN-Party. That's why I need a seatmap and an ticket system.
I found this CMS on GitHub that is perfect for my LAN-Party. The only thing is that I don't know how to use Django, CMS and python.
Link to project: https://github.com/lancms/lancms2
Link to free Django/Python/CMS hosting website: https://www.pythonanywhere.com
So I would be so happy if anyone could've helped me with this!
If someone just could make a quick tutorial or something how to set up the website!
Best regards, henriksen67
In this case the hosting site should provide a panel to host a django application. I don't know that hosting site but it can be that you copy-paste the CMS, select it as a Django application to run and then likely you from the shell have to install requirements. Check docs/support of the hosting site.
Note that this app is labeled as "Work in progress."
