The math is easy to do.
CL / (Frequency / 2) = Latency
CL is latency in # of cycles
Frequency in Mhz (divided by two since it is DDR) is million cycles per second
This equation gives latency in microseconds, multiply by 1000 to get nanoseconds.
So...
1. 11.7ns
2. 10.7ns
So the 3000Mhz has a lower latency, however, that's not the only important metric. It can also do many more cycles per second so it would be the better option in most uses anyway (especially when talking about Ryzen). That doesn't mean that if the latency was higher it would not still be the better option. My point is don't worry too much about latency and frequency only matters in certain use cases (or with systems that use IF like Ryzen).
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz 聽 CPU COOLER: Bequiet Dark Rock Pro 4 聽 MOBO: MSI X99A SLI Plus 聽 RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800聽 GPU: EVGA GTX 1080 SC2 iCX 聽 PSU: Corsair RM1000i 聽 CASE: Corsair 750D Obsidian聽聽 SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro聽聽 HDDs: Toshiba 3TB + Seagate 1TB聽聽 Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)聽 +聽 LG 29UM57 29" 2560x1080聽聽 OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz聽 MOBO: Gigabyte 990FXA-UD3 聽 RAM: 16GB dual-channel DDR3-1600聽 GPU: Gigabyte GTX 760 OC 聽 PSU: Rosewill 750W 聽 CASE: Antec Gaming One 聽 SSD: 120GB PNY CS1311聽聽 HDDs: WD Red 3TB + WD 320GB聽聽 Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV聽 OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)聽 Model: Dell PowerEdge T610 聽RAM: 16GB DDR3-1333聽 PSUs: 2x 570W聽 SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD 聽 HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB 聽 OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M 聽 Model: Dell Latitude E6530 聽 RAM: 8GB dual-channel DDR3-1600聽 GPU: Nvidia NVS 5200MSSD: 240GB TeamGroup L5 聽 HDD: WD Black 320GB 聽 Monitor: Samsung SyncMaster 2693HM 26" 1920x1200聽聽 OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/831726-memory-speed-question/#findComment-10401179
32 minutes ago, EOZ said:
Thank you! Just last question how much latency will be on DDR4 2133 CL14-14-14-35 ?
I just gave you the equation... plug in the numbers...
Just don't use latency as your only way to choose RAM... getting 2133Mhz RAM just because it has a lower latency than 3000Mhz RAM would be a poor choice...
Primary PC-
Album
Other Systems:
Home HTPC/NAS-
Laptop-
https://linustechtips.com/topic/831726-memory-speed-question/#findComment-10401508
