https://pcpartpicker.com/user/WhiteWulfe/saved/
That's my build. The RAM states that it can support 3000 MHz frequency. The question I have is do I have to OC currently because Ryzen cpus are still a bit new? Have driver updates been released that allow the RAM to be recognized automatically as 3000mhz instead of downgrading to 2133? Ended up getting the 3000 MHz RAM instead of the 3200 btw because of a bundle deal the site I got from had a good deal.
https://linustechtips.com/topic/830803-oc-ram-for-ryzen-system/
No you always have to set those manually, i advise keeping the overclocks down on the mobo you got
Don't buy Apple M1 computers with 8GB of RAM
https://linustechtips.com/topic/830803-oc-ram-for-ryzen-system/#findComment-10391610
Only thing I'd even OC would be the RAM because it states it supports up to 3000mhz
https://linustechtips.com/topic/830803-oc-ram-for-ryzen-system/#findComment-10391617
2
Your RAM OC depends on what motherboard you choose. Your motherboard you have listed hasn't been tested to see how well it OCs RAM. Here's a list of motherboards that have been tested.
Fan Comparisons 聽聽聽聽聽聽聽聽 F@H聽聽聽聽聽聽聽聽聽 PCPartPicker聽聽聽聽聽聽聽聽 Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/830803-oc-ram-for-ryzen-system/#findComment-10391725
I really really need help with this. I know Ryzen is good with higher speeds RAM, but my RAM is recognized as 2133...I'm not familiar with OC since that seems as if that's the only option I have. Can anyone give me specifics on this?
https://linustechtips.com/topic/830803-oc-ram-for-ryzen-system/#findComment-10391797
