What kind of files are you transferring? Couple of large files, thousands of small programs? Have you tried to narrow down any other possible causes, such as different flash drive, or an external hdd? If not, if you are comfortable, you may want to start dive into the bios and check settings there.
https://linustechtips.com/topic/829902-usb-30-low-speeds/#findComment-10383007
first thing, look if yuu're transfering them to a usb 3.0 storage unit, because if youre transfering from a usb 3.0 port to a usb 1.0 storage unit dont expect much, if youre using a usb 3.0 stick, then maybe you didnt install the usb 3.0 drivers (my msi board has both a driver and a utility tool) or maybe your stick isnt the best build quaity and cant handle all that data transfer... try a different usb stick, and open task manager when you transfer the files, look if anything gets maxed out, cpu, ram, disk usage and such. did you try different usb 3.0 ports in you pc? both front and back of the case? i dont think theres much more to troubleshoot...
https://linustechtips.com/topic/829902-usb-30-low-speeds/#findComment-10383012
On 9/2/2017 at 2:48 AM, Rajn said:
I've tried it before and it didnt work just like now. The speeds stay the same.
Edit: I just tried to transfer same file from usb stick to my pc and the speeds were 110mb/s.
          I can't understand what's wrong..
Have you tried writing files to the USB drive over USB3.0 on another computer? I've seen a TON of USB3.0 drives with fast read speeds, and absolutely shitty write speeds - some even slower than USB2.0 write speeds. Try the drive in another computer or try a different brand of USB3.0 drive.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/829902-usb-30-low-speeds/#findComment-10399056
