[HELP] Choosing an AMP/DAC unit
Go to solution Solved by Dackzy,
11 hours ago, RexAevum said:
Thank you for the responses,
I was considering the Audeze headphones mainly because of being able to get them for less than half the price and it was just too good of a deal to pass up for these headphones, I can get the LCD-x for around $500 and the EL-8 for around $300, the HD800/s was something i was considering for a later time. For this reason, i was considering of doing an upgrade to the AMP/DAC and since the aforementioned ones were in my price range I and i was hoping for a noticeable difference from my schiit stack and would also give me better connectivity with the pre-outs and XLR connections. If i understand correctly, neither of the ones are mentioned are a worthwhile upgrade over the stack i have.
If so, what is an AMP/DAC you could recommend me to consider, something that would be a good upgrade?
well they are upgrades, but they would kinda be wasted on Audeze headphones since they don't really show improvements in that regard very well.
For 1300$ you can get quite a few options, the Soekris 1421 and 1541 seem to get really good reviews from people I somewhat trust, those have an R2R DAC built in and a very well performing amp, but again I wouldn't really recommend getting one for LCD X or EL-8's.
Hello everyone,
**Looking into purchasing a new AMP/DAC combo unit that:**
1) Neutral, doesn't noticeably color the sound and is, most importantly, clear and detailed
2) Class A and able to run 600 Ohm headphones at good volumes
3) Comes with a 4-pin Balanced xlr and single ended connection
4) Can serve as a passthrough for powered monitors and other headphone amps (if i want to get a tube amp one day)
The main AMP/DAC units I have considered so far are:
* Questyle CMA600i
* Audio-GD NFB-28.38
* Oppo HA-1
Currently, I have a Schiit Modi 2 Uber and Magni 2 Uber.
I know the CMA600i and HA-1 are about $400 more than the NB-28, which brings me to the reason of my post:
1) Which device offers a better performance when it comes to Sound and ability to drive headphones? Clarity, neutrality etc.
2) Which would you recommend overall? And why?
 I will say visually the CMA600i wins in my book and the HA-1 wins when it comes to features but what I care more about is the performance. When reading online I have seen people praising all of them as an amazing device, for slightly different reasons, at the price.
**Headphones** I currently own: Philips Fidelio x2 and SHP9500, Audio Technica AD1000x, Audeze iSine 20.
I am also planning to get another set of Audeze headsets:
* EL-8 closed back
* LCD-x open
Which would be the better buy if I'm looking for a good overall headphone that is more neutral and, again very important, clear but with good bass (ignoring price difference between the two since I can get either one of them for half the retail cost)?
Will be used mainly for music and a little gaming.
https://linustechtips.com/topic/829422-help-choosing-an-ampdac-unit/
I would go for the Audio-GD IMO. Checking the reviews and specs, it seems to be a better buy. Though the CMA600i does look better and is much smaller in size compared to the other two.
For the headphones, I've heard a lot of headphones and for me I'd go for open back headphones if you're aiming for clear and neutral output.
Just my two cents
So you have three headphones that notoriously don't scale very well with better electronics with an IEM designed for mobile use, and you already own a Schiit Stack. The easy answer seems to be to get better transducers and thinking about amp pairing in terms of those. And given your current headphone upgrade path, I'd say think harder about what you're looking for in your transducers. Have you demo'd the EL-8C?
I have not, unfortunately, so all I'm going off of is reviews online
Since you already have the uber stack, I'd recommend getting the audio-gd if you're happy with your headphones. The uber stack should be sufficient to power all headphones with the exception of HE-6. If you're looking for an audible improvement with a better DAC/Amp, I would save for something more expensive after getting the headphones you want.
For headphones, I'd recommend the HD800 with SDR mod. Impressions on SBAF seem to blow any Audeze away with resolution, soundstage and clarity. However if you want us to tell you what you would prefer, it's not possible. You will have to try them yourself personally.
This makes zero sense to me.  All of the headphones you have listed scale badly or meh.
I basically agree with everything seduce me said.
If I were you then I would go out and try the HD 800 and HE 6, they both scale pretty well with gear and then once you have actually picked out your next headphones then I would recommend you to save a bit more up so you can get a DAC and amp that is a lot better than your modi 2 u and magni 2 u,  why? Because these smaller jumps are often not that impressive and will leave you with some form of upgrade itch, it might not be there the first or second year, but if you are anything like a big part of the audio community then you will get it. I would also recommend that you find out if you are okay with having two big boxes for your headphones or if you rather give up a bit of audio quality to get it to a smaller form factor
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
Thanks for the answer, I'll think about it and see what I go with
  • 1 month later...
SO, it's been a while now, what have you gone with? If you're undecided still, do give the HD800 + SDR mod a try. While a used HD800 isn't exactly cheap, it's reasonable compared to some high cans that have since been released. I BUMP'ed this thread because I'd gotten a pair of SDR from sorrodje (in an SBAF thread) and my oh my! My HD800 sounds really good to me, (though even before the mod the hot treble peaks didn't bother me,) my HD800 sounds more.......euphonic now, The treble seems to still retain its sparkle (though perhaps reduced a tad) while soundstage, imaging and detail still sound razor sharp. I like it! Maybe there's some unicorn fart and rainbow magic because the SDR were made by the man himself.:D
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
4 minutes ago, seduce_me said:
I have cork mod + SDR right now. Cork mod seems to remove the ringing and SDR changes the FR. Both work really well and I enjoy my HD800 a lot more now.
We basically have the 'HD800S' now.;) BTW, since you're here, do you think it's worthwhile for me to snag a legendary can (like the idea) in the HE6? I can snag a HE6 (with ohhgourami + grill mod), some scratches but seller is asking for about 900USD for it. I have the Oppo HA1 and a Gustard X12 + HA1 stack to drive it.
4 or 6 pin?
According to seller, it's the 6 screw version.....was that what you're asking? It also has the grill and blu tack mods done as well.
3 minutes ago, seduce_me said:
Yup, I heard the 6 screw one is more iffy than the 4 screw version so you might want to keep an eye out for that.
care to expand on that?:S
1 minute ago, seduce_me said:
Apparently the 4 screw is brighter, is more resolving and slams harder but the 6 screw has a more pleasant timbre and more air.
So, I take it that that means neither is superior, just a matter of sound preference, right?
Those are just impressions I read on discord, SBAF and other forums so it should just be a matter of preference. However, most of them sold their 6 screw and went for the 4 screw instead.
Ahh, noted, so it can be argued that the 4 screw version is better than the 6 screw version. I guess I'll wait for a stock HE6 to become available then, since I can then proceed to mod it however I like. The Cayin iDAC6 (glass top) + iHA6 stack looks to be what I'd be looking at next. thanks for the info!
