Hi guys.
i have h110i , i5 6600k and powercolor r9 390x devil
my cpu idle  was 32/30c
my cpu normal temperature was 50c on battleground for example
I was organizing my pc cables and fans ... etc like a normal person .
I changed my thermal paste before 2 month "mx-4"
after i finished organizing my cables thats happned.
gpu 50c idle , load 80c on battleground
cpu idle 50/55c idle
cpu load 90/100c on battleground
i restart my PC
gpu works good 32c idle , 55c load
cpu still same problem 50/55c idel , load 100/90c
I have no idea what's the problem is .
any help ?
https://linustechtips.com/topic/828393-cpu-95c-problem-help/
5 minutes ago, Anas Dweik said:
-SNIP-
Check your pump RPM's to ensure it is running and the pump hasn't died. If it's alright try remounting it with the high idle temps it's very possible a lack of mounting pressure.
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10367593
6 minutes ago, Anas Dweik said:
Hi guys.
i restart my PC
any help ?
Is it overclocked ?
Probably heatsink badly seated.
Take if off wash re-appy thermal paste, reseat heatsink bla bla bla
CPU: Intel i7 6700K 4.5 ghz / CPU Cooler: Corsair H100i V2 / Board: Asus Z170-A / GPU: Asus Rog Strix GTX 1070 8GB / RAM: Corsair Vengeance LPX 16GB DDR4 3000 mhz / SSD: Samsung 850 Evo 500 GB / PSU: Corsair RMx 850w / Case: Fractal Design Define S / Keyboard: Corsair MX Silent / Mouse: Logitech G403 / Monitor: Dell 27" TN 1ms 1440p/144hz Gsync
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10367596
Before you star dismantling anything make sure your pump is plugged in to power and is running and that both fans are spinning.
Main Rig:-
Server:-
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10367602
Just now, Anas Dweik said:
no , i changed it before 2 month
I suggest watch youtube on how to apply thermal paste and also maybe a tutorial on how to install your specific heatsink.
Could help. Even the best sometimes, with new hardware or heatsink etc can still need some help :P
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10367614
its not the first time i install my cpu cooler , i am sure there is no problem in installing the cooler , i will try to reapply my thermal paste
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10367622
Usually there are not like 10 things related to 100c cpu : Fan not plugged, no power, pump not working, no thermal paste, heatsink badly seated.
I don't see other things to verify but other people here maybe can help better
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10367625
2 minutes ago, Anas Dweik said:
mx-4 , 70% alcohol , i do know how to apply thermal paste
My friend had same issue, and even after he told me 10 times he know how to install the heatsink, I figured out there was 1 clip missing and due to that, bad contact, he was getting 100c temp.
Not saying its ur case, but first thing to do wud be like other said, verify fans, pump, take heatsink off, wash, apply thermal paste, reseat , verify temps after and let us know :)
GL buddy
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10367631
1- fans plugged they are spinning behind me
2- idk what do u mean in no power
3- i have no pump its h110i from corsiar  locked water cooling
4- i changed thermal paste before 2 month "MX-4"
5- i will try to reinstall the heatsink
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10367634
GL buddy
i will try to do it right now
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10367643
GL buddy
Still same problem
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10367772
2 hours ago, Anas Dweik said:
Any help ?
The pump is running and everything is functional?
If so do you notice the mount loose at all, you might want to consider looking into the washer mod by adding some rubber orings.
http://www.overclock.net/t/1465656/concerns-about-newly-installed-corsair-h100i
https://linustechtips.com/topic/828393-cpu-95c-problem-help/#findComment-10369126
