Will my RAID survive a case swap?
Solved by Ninjakub,
26 minutes ago, RadiatingLight said:if none of the hardware changes, it should work like a charm.
your PC won't even know anything is different.
but yes, ideally keep them in the same SATA ports.
you can just take a picture, unplug them, and then plug them into the same ports when you're rebuilding.
alright thanks, it should be easy enough to make sure they return to the proper ports
