Hi All!
I have a build planned for the next year (still saving up, and it is liable to change). I have become interested in the idea of mounting a GPU vertically, to display that RGB goodness, and show off how stunning the card is. My card will likely be the Gigabyte GTX 1070 XTREME Gaming 8GB, and the case I am definitely buying is the Cooler Master Mastercase Pro 5. I have looked around on the internet, and I haven't been able to find any cumulative tutorials on the process of vertically mounting a card, nor any places in or around Australia where I can purchase the necessary components. If someone could explain this process, it would be greatly appreciated :)
Jaeger
HEADS UP, THIS ACCOUNT IS INACTIVE NOW
I'm keeping everything else the way it was for anyone who might check out my answers in future, but I won't be using LTT.
Don't forget to quote me when replying to me!
Please explain your question fully, so I can answer it fully.
PSU Tier List Cooler Tier List SSD Tier List  My Specs Below!
My PC:
CPU: Ryzen 5 1600 @ 3.2GHz
Cooler: Stock Wraith Spire
RAM: G.Skill Trident Z RGB 3000mHz 16GB DDR4 (2x8GB) RGB
Motherboard: Asus ROG Strix X370-F Gaming ATX
SSD: Crucial MX500 500GB 2.5"
HDD: Western Digital Blue 1TB 7200rpm
GPU: Asus ROG Strix OC GTX 1060 6GB
Case: Cooler Master H500P
PSU: Corsair RM650i 650W 80+ Gold Fully Modular
OS: Windows 10 Home 64-bit
Fans: 4x Cooler Master Masterfan Pro 120 Air Balance
Potato Laptop (Samsung Series 5 Ultrabook, 2013):
CPU: Intel Ivy Bridge i5 3337U @ 1.8GHz
RAM: 8GB DDR3 2133mhz SODIMM (1x4GB Samsung, 1x4GB Kingston)
SSD: Kingston 24GB SSD (originally for caching)
HDD: HGST 500GB 5400rpm
GPU: Intel HD 4000 Graphics
https://linustechtips.com/topic/828150-vertical-gpu-mount/
7 minutes ago, JaegerB said:
Hi All!
Jaeger
What you would need is this adapter bracket:
https://store.coolermaster.com/vertical-display-graphics-card-holder
https://www.mwave.com.au/product/cooler-master-universal-vertical-vga-card-holder-and-pcie-x16-riser-cable-ac06887
Edited by W-L
https://linustechtips.com/topic/828150-vertical-gpu-mount/#findComment-10365308
7 minutes ago, W-L said:
Cool, exactly what I was looking for! How would this go into the case? Would it replace all slots?
My PC:
https://linustechtips.com/topic/828150-vertical-gpu-mount/#findComment-10365336
Yes it's designed for that case so you take out all the PCI-E slots and use the bracket instead. Note the second one comes with the PCI-E extension which you'll need.
https://linustechtips.com/topic/828150-vertical-gpu-mount/#findComment-10365341
Great, thanks for answering! This seems a whole lot easier than the janky obscure tutorials I found on youtube :)
My PC:
https://linustechtips.com/topic/828150-vertical-gpu-mount/#findComment-10365346
Some modding will still be required if you plan on using anything else in one of your free PCIe slots.
https://linustechtips.com/topic/828150-vertical-gpu-mount/#findComment-10368926
That's alright, I don't need any other cards.
My PC:
https://linustechtips.com/topic/828150-vertical-gpu-mount/#findComment-10369740
Would this sort of thing work in cases (with 7 slots) other than the listed ones, if I were to cut out the horizontal bars in the way?  I was looking to mod in a vertical mount for my Lian Li PC-O9, and this was the first option I found.
CPU - 1700X 3.7gHz | CPU Cooler - EK and Singularity Custom Loop | Motherboard -  Asus X370 Crosshair VI w/ EK Monoblock | RAM - Corsair Vengeance RGB (4x8GB) 3000Mhz w/ Silver Paint| Graphics Card - Asus GTX 1080ti Strix OC w/ EK Fullcover block with custom vertical mount | Power Supply - Corsair HX750i w/ self made Custom Cables and 3D printed Combs | Storage - 3x 3TB, 2TB HDD | Samsung 960 EVO 500GB NVME SSD, 500GB OCZ SSD | Case - Lian Li PC-09 Custom paint | Colour Theme - Silver & Black & RGB lights
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Logitech MX Master 2S Mouse/Wacom Intuos Pro5 Med
https://linustechtips.com/topic/828150-vertical-gpu-mount/#findComment-10376309
If you have horizontal bars between the PCI-E slots your going to need to cut them out if you want to use that GPU adapter.
From looking at photos of the case it looks like your going to need to do some cutting.
https://linustechtips.com/topic/828150-vertical-gpu-mount/#findComment-10376326
Thanks W-L!  If I decide to go that route, Im sure itll be a fun project!
https://linustechtips.com/topic/828150-vertical-gpu-mount/#findComment-10376335
