There's probably an option in the Play store app somewhere.
Dig around, and you should be able to find it somewhere.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/828009-phone-storage-problem/#findComment-10363926
I dug all I could to no avail, that's why I decided to come and ask the pros here at ltt lol
https://linustechtips.com/topic/828009-phone-storage-problem/#findComment-10363948
ok so go to your setting storage and see if it is formatted as internal there you can either reformat it to be an internal storage or external sd card.
if its internal that means android will use it to store everything in that partition until its full then it will move on to the real internal but if its external that means its only used as if u used a usb stick
https://linustechtips.com/topic/828009-phone-storage-problem/#findComment-10363959
Life Saver. Thanks
https://linustechtips.com/topic/828009-phone-storage-problem/#findComment-10363984
by the way, i forgot to say but if your phone is rooted you can split your sdard  in 2 partitions one being external and one being internal using app2sd app i personally use it on my 256Gb sd card in 2 128gb partitions if you have questions about that ask me
https://linustechtips.com/topic/828009-phone-storage-problem/#findComment-10363999
