My PS3 controller broke, so I was searching for a new one, the XOne is fully compatible with the PC, but it costs more (including PC adapter) and I'm more used to the PS layout, on the other hand, the PS4 should work with bluetooth wo extra adapters, but it's not officially compatible (AFAIK) and I'm not sure if it would work with my Bluetooth Headphone connected at the same time. Any suggestions?
https://linustechtips.com/topic/827233-ps4-or-xone-controller-for-pc/
forgot to quote :)
ask me about your system builds, AIO's, CPU's, PSU's, and GPU's.
1 minute ago, ricksteendam1 said:
it depends on you they both work but most games will give a Xbox button layout with a few exceptions
I'm used to the buttons, I'm wondering more if it works just fine or if I'll have to install something, those things
Xbox will have better support because microsoft owns xbox but for the most part a ps4 controller will work. I prefer an xbox controller
if you have the drivers installed they both work fine except the while gaming with a ps4 controller still will show you which button to push if you have a Xbox controller which is ferry irritating because in every game its different
Don't really like the 360 controller, and I'll have to buy an adapter anyway, so I prefer the One
if you don't have a half hour to instal drivers buy the official receiver
8 minutes ago, ricksteendam1 said:
forgot to quote :)
You shouldn't quote the OP if you're in the first hour or so.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
I'd go with the One controller. You can find them in Bluetooth or Wireless (via dongle) varieties.
Just now, Murilo_A said:
Is it possible to use the One with Bluetooth?
Like I said, there's one for Bluetooth (updated version) and another for the dongle (original).
I included a link for the Bluetooth.
3 minutes ago, Murilo_A said:
Ohh, thanks, btw, does this work with a Bluetooth Headphone?
The Bluetooth headset would connect to the machine [(Xbox One or PC)], not the controller. Also, you do need a Bluetooth adapter to use it as one isn't included in the box.
No, but obviously you could still just pair those to your PC as well. The newer (newer being anything after the launch controller) controllers all have a 3.5mm headphone jack, but if you use one of those I think your range gets cut down to something like 10 feet before the audio drops.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
3 minutes ago, ARikozuM said:
The Bluetooth headset would connect to the machine, not the controller. Also, you do need a Bluetooth adapter to use it as one isn't included in the box.
Yes, I know that, I have a Bluetooth adapter, I'm asking if it works with the headphone connected at the same time
My headphone doesn't have a 3.5mm jack, I'm asking if I can connect the headphone and controller to the PC at the same time
Most Bluetooth adapters (good ones like the Asus and higher) can support four simultaneously. Bluetooth 4.0 can support eight, I believe, but most manufacturers still state four devices max.
I have a USB-BT400 from Asus should it work?
That's the Asus I mentioned, so yes. It should have no trouble connecting to your controller and headset.
  • 3 weeks later...
Update: I actually bought the PS4 controller, not only I prefer to the PS layout, but it was cheaper. Support for the controller is great and it's working perfectly and bluetooth worked fine
Make sure you post a Member Review of the setup so that we can link to it. That's if you want to.
