Hey Guys!
I was recently planning a PC build on PCPartPicker, when I ran into a problem.
I had put an Intel i5-7500, a GTX-1060 and i was looking for a motherboard when my friend suggested the MSI H110M Gaming. I wasn't sure on it, but I rolled with it.
However, when i selected it for my concept build, it said the following:
Some Intel H110 chipset motherboards may need a BIOS update prior to using Kaby Lake-S CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions.
Anyone knows what this means? and what to do??
Also, if you have any recomendations for a Motherboard, lemme know
Thanks in advance!
Spiz~
https://linustechtips.com/topic/826105-compatibility-issues/
Any H110 board needs a BIOS update to use Kaby Lake CPUs.
Any B250 board should be fine.
Edited by idiot42
i7-12700k | MSI PRO Z690-A DDR4 | 2x16GB Team Group DDR4-3200CL14 | be quiet! Dark Rock Pro 4 | EVGA FTW3 2070 SUPER | 500GB Samsung 970 EVO Plus | 4TB Seagate Barracuda 5400RPM | Fractal Design Meshify C
https://linustechtips.com/topic/826105-compatibility-issues/#findComment-10343048
You didn't write the message, but i'm guessing there were compatibility issues. Older chipsets such as the H110/H170/Z170/etc... require a bios update to use Kaby Lake CPUs.
I'd suggest using something like:
https://pcpartpicker.com/product/pCqbt6/msi-h270m-bazooka-micro-atx-lga1151-motherboard-h270m-bazookaInsert other media
Current Build
Successful Builds
https://linustechtips.com/topic/826105-compatibility-issues/#findComment-10343053
yeah i think i know what to do. Thanks for the help!
https://linustechtips.com/topic/826105-compatibility-issues/#findComment-10343110
