7 minutes ago, omeir20003 said:
So I have a 1500x with the stock cooler but when its on it goes to 70-77 degrees celsius so I'm thinking to switch to another cpu cooler. Which one should I get?
do a custom water cooling loop man. its the way to go
- YEET
"If you gon be bout it, be bout it bout it" ~ Gavin 'itsjusta6' Simon
I play games - Look at my profile for specs
I love memes. I make bad memes, but I like dank memes, who doesn't?
I am good at editing videos and pictures, feel free to message me if you would like some work done.
Thanks!
Kole Overby
Owner At:
Chaos Network
DanTheNali Videography
Employee At:
Neighborhood Mechanic
Heinen's Powersports
https://linustechtips.com/topic/825834-cpu-cooler/#findComment-10340132
- YEET
On a 1500X? You've lost it, man. There's absolutely no reason to put a custom loop on a 1500X. Hell, my 1700 reaches unsafe voltages before coming anywhere near thermal throttling, and I'm only running an H5 Ultimate.
@omeir20003, the Cryorig H7 is a solid stock replacement that will let you get a very nice overclock, and there's an AM4 kit that they'll ship you if you need it. The M9a is a smaller, cheaper Cryorig cooler that will cool on par with a Hyper 212 EVO.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/825834-cpu-cooler/#findComment-10340151
i kno. could you not tell that i was meming?
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/825834-cpu-cooler/#findComment-10340154
I don't speak yeet.
everybody on the internet speaks YEET
Thanks!
Kole Overby
Owner At:
Chaos Network
Employee At:
https://linustechtips.com/topic/825834-cpu-cooler/#findComment-10340158
8 hours ago, omeir20003 said:
I was thinking to get the Noctua NH-U12S cuz my budget is 100 dollars is that a good choice?
Its good choice and one I would pick rather than cheap coolers.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/825834-cpu-cooler/#findComment-10341264
Yes, the NH-U12S is very hard to go wrong with in most situations.
https://linustechtips.com/topic/825834-cpu-cooler/#findComment-10344011
