I'm having a problem with my USB drives not being recognised on Windows 7. I don't get any messages saying they aren't recognised, I just get the sound that plays when you plug in a device, but the explorer shows absolutely nothing, except a generic "Removable Disk" drive (as opposed to showing the actual name of the drive and the icon selected for it.), and clicking on that.
I've tried this with a few USB sticks I have and it does this with all of them.
I tried rebooting and going to the boot menu to see if the PC itself is recognising them, and it does, so it must be a problem with Windows 7.
What do I do?
https://linustechtips.com/topic/825496-usb-drives-not-being-recognised/
Okay, I looked at device manager, and saw there was a USB port with a warning sign, suggesting that there's no driver installed, so I got the driver from the motherboard manufacturer's website, and installed it.
It worked at first, but then it just stopped working again.
It only seems to work whenever it feels like it, like some days it works perfectly without problems, but6 another day it won't work at all.
I'm totally at a loss now, does anyone have any ideas?
did you get the unrecognized USB device popup in windows ?
Home PC:
CPU: i7 4790s ~ Motherboard: Asus B85M-E ~ RAM: 32GB Ballistix Sport DDR3 1666 ~ GPU: Sapphire R9 390 Nitro ~ Case: Corsair Carbide Spec-03 ~ Storage: Kingston Predator 240GB   PCIE M.2 Boot, 2TB HDD, 3x 480GB SATA SSD's in RAID 0 ~ PSU:    Corsair CX600
Display(s): Asus PB287Q , Generic Samsung 1080p 22" ~ Cooling: Arctic T3 Air Cooler, All case fans replaced with Noctua NF-B9 Redux's ~ Keyboard: Logitech G810 Orion ~ Mouse: Cheap Microsoft Wired (i like it) ~ Sound: Radial Pro USB DAC into 250w Powered Speakers ~ Operating System: Windows 10 Enterprise x64
Work PC:
CPU: Intel Xeon E3 1275 v3 ~ Motherboard: Asrock E3C226D2I ~ RAM: 16GB DDR3 ~ GPU: GTX 460 ~ Case: Silverstone SG05 ~ Storage: 512GB SATA SSD ~ Displays: 3x1080p 24" mix and matched Dell monitors plus a 10" 1080p lilliput monitor above ~ Operating System: Windows 10 Enterprise x64
Are they USB 3.X? Windows 7 doesn't have native USB 3.0 support, and you'll need to install drivers for them to work.
You said you installed drivers, but that it's not working reliably. Which drivers did you install? Maybe another driver will work.
https://downloadcenter.intel.com/download/21129
https://downloadcenter.intel.com/download/19880
You own the software that you purchase - Understanding software licenses and EULAs
"We’ll know our disinformation program is complete when everything the american public believes is false" - William Casey, CIA Director 1981-1987
Nope. I get absolutely nothing.
Some are 3.0, some 3.1, and some pre 3.0, and the drives don't work on either.
I looked up my motherboard online, and found the driver downloads at the manufacturer's website. They drivers didn't work, though.
On 26/8/2017 at 2:23 PM, LoGiCalDrm said:
Do other peripherals work on those ports?
Yeah, my Xbox One controller, my microphone, my drawing tablet and my external floppy drive all work just fine...
