The Msi gtx 1070 has a 8pin connector socket and a 6pin connector socket whereas my PSU only has a 6+2(8) pin connector.
Will the GPU be able to run on a 8pin connector and if so will there be any performance impacts for not using both the 6 pin and 8pin connector?
Also, will this cause any problems with overclocking?
https://linustechtips.com/topic/825465-8-pin-connectors/
You use the 6+2 to make an 8 ping connector. Join the 6+2 together..
EDIT: Nope, it won't work you need to use both 8+6. Which PSU do you have?
Image result for 6+2 pin pcie
https://linustechtips.com/topic/825465-8-pin-connectors/#findComment-10336222
I'd say that it's not possible to run it on just the 8 pin connector, as it will not be supplied with enough power to run correctly.
i7-12700k | MSI PRO Z690-A DDR4 | 2x16GB Team Group DDR4-3200CL14 | be quiet! Dark Rock Pro 4 | EVGA FTW3 2070 SUPER | 500GB Samsung 970 EVO Plus | 4TB Seagate Barracuda 5400RPM | Fractal Design Meshify C
https://linustechtips.com/topic/825465-8-pin-connectors/#findComment-10336228
2x Sata --> PCIE 6pin
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
https://linustechtips.com/topic/825465-8-pin-connectors/#findComment-10336320
NOPE NOPE NOPE NOPE NOPE! That bus is not rated for that kind of power!
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/825465-8-pin-connectors/#findComment-10336336
shshshsh, the card will boot up thats all that matters. its like when my 750ti needed it, it didnt actually, but i had to have one anyway. (maybe not in this case but i've seen 1070's with just one 8pin)
Specs v-v
https://linustechtips.com/topic/825465-8-pin-connectors/#findComment-10336341
The manufacturer put those connector for a reason.
To put the demanding cables in it...... is this topic for real??
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/825465-8-pin-connectors/#findComment-10336343
You're confusing me, can you english harder?
Specs v-v
https://linustechtips.com/topic/825465-8-pin-connectors/#findComment-10336350
Yes you MUST put both connectors or don't use the GPU at all, its so simple
https://linustechtips.com/topic/825465-8-pin-connectors/#findComment-10336388
The gpu wont work without both.
Specs v-v
https://linustechtips.com/topic/825465-8-pin-connectors/#findComment-10336391
